miniDSP/miniDIGI/miniAMP noise problem - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 26th September 2013, 10:01 PM   #1
Defo is offline Defo  Norway
Default miniDSP/miniDIGI/miniAMP noise problem
Hello,
Since I don't recieve any response from miniDSP support, I'll try here..
Two problems:
- High noise in speakers connected to the miniAMP. Noise is redused considerably when miniDSP is distached from the setup (ie. running only the miniDIGI and miniAMP).
When powering up the whole module, the noise is at an acceptable level, but as soon as an audio signal is present, the noise is elevated to a much higher level, and stays so until I power down the module again. I use the optical input on the miniDIGI.
- Volume potentiometer not working as it should (volume is high, even though the potentiometer is turned all the way down, in which case it should be completely silent).
Pictures of each board attached.
Help please?
Old 26th September 2013, 10:37 PM   #2
one little thing to note, the volume potentiometer never goes to zero. Volume should be controlled before or after. Bit stupid design.
I just got my dsp/digi/amp working, whats your power source?
Old 26th September 2013, 10:48 PM   #3
Thanks for the reply.
I've tried several different power supplies, so it doesn't seem to be an issue with the power adapter. The noise is still quite high.
The miniAMP is connected to a pair of horns with compression drivers, so some noise is to be expected. But I experenced less noise with other amplifiers that inhibited quite low s/n ratios, so I would expect the miniAMP more or less silent due to its pure digital design.
While it does seem to be more of an issue with the miniDSP rather then the miniAMP, since the noise is only present when an audio signal is present (that is, I start playing some music). Before that, the noise is quite low.
Old 27th September 2013, 08:48 PM   #4
If it is the MiniDSP volume, check out this guide:
Potentiometer Volume control down to -100dB
MiniDSP :: Topic: Potentiometer Volume control down to -100dB (1/1)
Minidsp/MiniDigi/Miniamp + MiniDsp/MiniAmp gmant123 miniDSP 0 10th October 2012 06:11 PM
Stereo 3-way with minidigi/minidsp 2x8...minidigi jumper/4x10 routing configuration? architect7 miniDSP 2 23rd March 2012 08:31 AM
MiniDSP/miniDIGI/miniAMP article JohnR miniDSP 4 1st November 2011 10:12 AM
MiniDSP, MiniDIGI, MiniAMP 2.1 Setup Franz Gysi Digital Line Level 22 3rd April 2011 09:53 AM
miniDIGI + miniAMP: An SPDIF amplifier minidsp miniDSP 10 20th March 2010 05:40 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
