please critique my pcb - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 15th August 2013, 01:19 AM   #1
Default please critique my pcb
i did a quick and very dirty job on differential tda1541 design tonight. this is my first foray into eagle so please do keep my feelings in consideration, heh.
the reason for cs8412 being in the middle, oversized decoupling caps, double row smoothing caps... well, call it a mass appeal. i tried to completely separate digital and analogue section.
you can obviously see salas shunts and the coax input is of peter daniels' design.
i have no skill and time for optimal layout and all. if the circuit should work, that's good enough for me to do a test print.
the output will be 1:20 trafo. suggestions for an active stage would be appreciated. thank you all.
http://postimg.org/image/5jblakfs7/full/
free image hosting
Old 15th August 2013, 01:25 AM   #2
dp
Old 15th August 2013, 09:37 AM   #3
Over 70 gents stopped by without comment. It must be hopeless...
Old 15th August 2013, 10:54 AM   #4
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Could just be that you're giving off mixed messages. On one hand, you want comments, but on the other hand you 'have no time for optimal layout' - thus people who have experience of doing this are going to steer clear. Its time consuming to examine another's layout so they'd want more reassurances their suggestions will get implemented.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 15th August 2013, 11:41 AM   #5
of course i would like to implement them eventually but as for now i just would like to know if there's any mistakes that are glaringly obvious.
in short i'd like a quick fixie if the circuit needs it
(and high mind suggestions for future artwork.)
right now i'm most concerned about all the vias jumping layers. is that a ticket for ground loop?
here's a little edit i did with grundig dem reclock implemented.
http://postimg.org/image/5qf7gk0u7/full/
Old 15th August 2013, 11:59 AM   #6
Avro Arrow's Avatar
Just a couple of quick suggestions....
You should limit your wire angle to 45 degree increments.
Curved traces are fine to use.
Where two traces meet, should be limited to 90 degrees.
If two traces meet at more acute angles, chemicals can get
trapped and cause trace failure.
The polygon command can be used to make thick traces as well as
filled planes.
Old 15th August 2013, 12:03 PM   #7
Same regulators for both dacs ?!
no local decoupling for the tdas ?!
all sorts of currents in the return paths to tda gnd of the dem caps
where is agnd and dgnd of the tdas connected ?!
Old 15th August 2013, 12:05 PM   #8
marce is offline marce  United Kingdom
Ground loops are not realy an issue on PCB's, for the digital you are better of with a ground plane for optimum signal integrity.
Your power tracks to the devices are very thin...
Tracking is scruffy and the placement could be optimised, I would start again.
Old 15th August 2013, 12:46 PM   #9
thank you gents.
tazzz, digital and analogue has completely separate grounds. i thought that would be ok but smarter suggestion would be appreciated.
is it worse or impossible to share regulators? i've been doing that for differential 1543 with pleasant results. for 1541 that would mean 6 regulators *gasp
Old 15th August 2013, 01:23 PM   #10
To illustrate the comments on routing here is a picture that illustrates 90/45 degree corners and neat routing. DONT use curved traces, they are hard to do and serve no purpose what so ever other than make layout even harder.
When I said start again, the best way to get proficient at PCB design is to practice.
Again for best signal integrity ALL digital lines should run over a contiguous ground plane to provide the best return current path.
A link that explains the reasons...
http://www.x2y.com/filters/TechDay09...%20_JohnWu.pdf
Please critique my PCB design darkfenriz Class D 26 8th August 2008 03:49 PM
Our Aleph 2 PCB - Critique please! TwangBar Pass Labs 9 23rd October 2007 11:27 AM
3886 PCB critique rayban68 Chip Amps 8 20th April 2004 03:43 AM
1st PCB - critique, please! sobazz Chip Amps 16 24th March 2004 09:40 PM
Please critique my Gainclone PCB Felix Chip Amps 33 11th January 2004 03:25 PM
Copyright 1999-2017 diyAudio
