I2S slave mode w/o master clock to S/PDIF - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 12th August 2013, 12:46 PM   #1
Default I2S slave mode w/o master clock to S/PDIF
In several occation I've had a I2S signal available inside equipment, where I wanted to pick up the I2S signal and send it outside the equipment as a S/PDIF signal.
Last case was my car radio.
In that case, as well as on some other cases there is no 128/256/512*Fs master clk. Only the 64*Fs bitclk. They probably sample rate convert the signal where it is recieved.
So we're talking a stand-alone slave mode S/PDIF modulator with a clock doubler.
I don't know of a S/PDIF modulator IC that can run in slave mode, and internally double the bitclk to make the double freq for the biphase coding.
I wouldn't make a birds nest construction in the enviroment of a car, and basicly it would be easier and cheaper if there's a small PCB for this for sale on the net.
Do you know a (small) board for this? Or maybe a single chip I've overseen, that can do it? I'm not looking for extreme quality and VCXO's..
Best Regards, Eskil
Old 17th August 2013, 08:00 PM   #2
Chip: WM8804 - MCLK source can be a 12-MHz xtal.
PCB: Twisted Pear S/PDIF Transceiver module.
Old 17th August 2013, 08:13 PM   #3
Thanks - I studied that one, prior to asking. As I read the datasheet, the 12MHz Xtal and PLL only works in master mode. The PLL does not sync to an incoming bitclk, only to an incoming S/PDIF. Is that a misunderstanding? Doesn't the MCLK have to be synchronous to the bitclk?
Old 18th August 2013, 01:28 AM   #4
dmills is offline dmills  United Kingdom
Xor gate and an RC network to double the clock, then whatever you normally use for a transmitter.
Use a picologic gate and a few 0603 parts, should be nearly trivial to throw together.
Regards, Dan.
Old 18th August 2013, 08:53 AM   #5
Hi Dan, thanks for your kind reply.
It's a good point that a XOR gate and a RC Network can make a clock doubler. It will add a lot of jitter to the spdif stream, but that's probably not a problem in my car.
I don't trust a birds nest construction in a car, for reliability/vibration reasons.
Basicly I'm asking if there's a small cheap PCB out there that does it. It seems like there isn't. Thanks everyone for the replies!
DAC in Master, CD in Slave mode - How? spavleski Digital Source 22 10th April 2013 09:26 AM
Master DAC for a Slave soundcard Irakli Digital Source 4 23rd April 2011 11:35 PM
clock, master/slave no clock? pforeman Digital Source 0 29th January 2011 07:17 PM
I2S: Master Clock relationship with BCLK and LRCLK mahen.jnk Digital Line Level 0 27th August 2010 06:05 PM
CS8416 in sw slave mode with external clock milandks Digital Line Level 0 29th March 2009 10:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
