What makes an R-2R DAC nonmonotonic?
Old 17th July 2013, 11:39 PM   #1
bcarso is offline bcarso  United States
diyAudio Member RIP
Default What makes an R-2R DAC nonmonotonic?
So, after noticing that few DAC manufacturers supply even the nominal output resistance of so-called current output DACs, and as well remarking on other threads that various I-V converters will have issues interacting with the finite output resistances, I started looking in the literature for information on just what the behavior would be for R-2R-network-based DACs.
After consulting a few books and searching online, I've yet to find this material discussed, other than in the form of generalities and admonitions. I'm certain it is out there in the literature somewhere, but I haven't managed to find it. So I decided to do some calculations and simulations.
I selected the network resistance to be 1kohm. So each bit switch pulls a 2k resistor to one of two current output lines, which are then terminated in variable resistances. Each output line was sequenced through the complete set of codes, and the criterion for comparison was the threshold of departure from monotonicity. That is, when a code increase produced no change from the preceding code, that termination resistance was noted. There is an appreciable effect due to where one is in the code ramp, and I may publish the detailed data in some form or another.
But I thought some sense of the magnitude of the effects might be informative.
Working with relatively low-resolution to begin with, here are some results from simulation:
Threshold of non-monotone behavior, values in ohms at each output:
3 bits: 2.055k
4 bits: 773
5 bits: 353
6 bits: 108
7 bits: 50.1
8 bits: 20.2
9 bits: 11.9
So it can be seen that even for quite modest resolutions, the necessary approximation to a virtual ground is fairly stringent.
Now, of course a lot of audio DACs are constructed with low-resolution networks towards the output(s), and use noise-shaping oversampling delta-sigma techniques and resulting pulse-density outputs rather than strictly R-2R networks. Even with this however it can be important to terminate in reasonably low impedances for best results. There is also some anecdotal material that reports a preference for the sonics of multibit converters.
The manufacturers' almost universally recommended I-V converters are one or another opamp with the current fed in directly to the inverting input(s) and some passive network for feedback that sets the bandwidth and current-to-voltage conversion gain. Others, noting the large amounts of spurious high frequency energy in the DAC outputs prescribe various passive filter networks ahead of the opamp inverting input(s). But consideration of the above numbers suggests that this may spoil things very easily.
What I am drvinig towards is a reconsideration of the basic notions of I-V converter achitectures, and was inspired in this regard in particular by various recent discrete solutions, in particular those of EUVL's "Sen" circuits as a starting point. While these designs are in gestation I thought it would be nice to at least motivate them by getting some idea of what constitutes an adequately low input impedance.
Brad Wood
Old 18th July 2013, 12:20 AM   #2
kevinkr's Avatar
Interesting.. I currently use ~3 ohm I/V resistors with PCM1794A which noted of course is not an R2R dac..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 18th July 2013, 01:53 AM   #3
diyAudio Member RIP
From the datasheet: "The PCM1794 uses TIís advanced segment DAC architecture to achieve excellent dynamic performance and
improved tolerance to clock jitter. The PCM1794 provides balanced current outputs.
Digital input data via the digital filter is separated into 6 upper bits and 18 lower bits. The 6 upper bits are converted
to inverted complementary offset binary (ICOB) code. The lower 18 bits, associated with the MSB, are processed
by a five-level third-order delta-sigma modulator operated at 64 fS by default. The 1 level of the modulator is equivalent
to the 1 LSB of the ICOB code converter. The data groups processed in the ICOB converter and third-order
delta-sigma modulator are summed together to create an up-to-66-level digital code, and then processed by
data-weighted averaging (DWA) to reduce the noise produced by element mismatch. The e data of up to 66 levels from
the DWA is converted to an analog output in the differential-current segment section.
This architecture has overcome the various drawbacks of conventional multibit processing and also achieves
excellent dynamic performance."
So it sounds like we are close to a 6-bit final output current DAC here. If we knew its Z we could evaluate the maximum termination Z for best-case monotonic performance.
Of course using extremely small R values for a passive termination entails some rather suboptimal signal-to-noise ratios.
Old 18th July 2013, 02:13 AM   #4
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Interesting. There appears to be audiophiles happy with terminations as high
as 1 Kohm.
Old 18th July 2013, 02:19 AM   #5
diyAudio Member RIP
as 1 Kohm.
Well we know about them
Seriously of course, low-bit final stages in delta-sigma DACs, and/or closer-to-true current output ones (i.e. genuinely high-Z which the name implies but seldom delivers on) are each more immune to significant voltage burdens.
Old 18th July 2013, 02:43 AM   #6
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
The higher value terminations I've seen mainly on TDA1543 and TDA1387 (which is my current favourite) - neither are R2R but segmented current source. I can't say as I've noticed SQ variation in going up from 50R to a few hundred ohms on the 1387.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 18th July 2013, 03:01 AM   #7
kevinkr's Avatar
Originally Posted by bcarso View Post
<snip>
Yeah, there are some tradeoffs. The resolution of this particular design is noise limited in the analog path.. Details of the offending I/V converter design can be found here: http://www.diyaudio.com/forums/tubes...rrent-dac.html
I had a bit of fun, but I do eventually plan to increase the value of those resistors to increase output level a few more dB.. I'm pretty satisfied with the performance even though I readily admit the measurements (and calculations) indicated I am throwing away available bits.
I've heard the 1794A driving a 1K resistor single ended, was not impressed.. lol
Old 18th July 2013, 03:04 AM   #8
diyAudio Member RIP
Do they actually disclose the impedances? The bother about so much of this stuff is the imprecision of nomenclature. A person relatively new to electronics, but possibly well-schooled in fundamentals, could reasonably assume that a "current source" is rather high impedance. But of course in the Land of DACs it can be anything but.
But sound quality is just that. For all I know some nonmonotone behavior could turn out to be mellifluous, though I'd tend to be dubious at first glance.
Yet to be done is an analysis (probably best done in Mathcad and the ilk) of HD and IMD as a function of these specific code-related variations. I would intuitively suspect that some rather high-order distortion terms would appear, albeit at relatively low levels. But it doesn't take much at some orders to be potentially obnoxious.
Old 18th July 2013, 03:09 AM   #9
diyAudio Member RIP
I'm confident that some strategies could easily realize a sub-three-ohm input termination out to high frequencies, without other concomitant deficiencies, and not be the noise limitation.
Old 18th July 2013, 03:56 AM   #10
abraxalito's Avatar
Not to my knowledge no, and I've digested the DSs fairly thoroughly. They do separate out the DC compliance from AC though and recommend a maximum 25mVAC on the 1543. No such strictures on the 1387.
Indeed so on R2R, less so on segmented current sources I reckon but I have no measurements to back this up other than a multitone test with multiple DACs in balanced mode. I'm unclear how nonmonotonicity would relate to such a measurement.
I guess I lack sufficient cynicism to make the leap from 'quality' to 'mellifluous'
What makes an R-2R DAC nonmonotonic?Hide this!Advertise here!
Power R-2R ladder DAC? cuallito Class D 2 3rd May 2011 02:33 PM
A good way to reduce R-2R DAC linear error AD1865 Digital Source 103 27th May 2005 02:55 PM
Any 32bit Delta Sigma/ R-2R Audio DAC in the world? Comzone Digital Source 3 11th February 2004 03:01 PM
Copyright ©1999-2017 diyAudio
