AD1862 digital supply voltage - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th July 2013, 10:31 PM   #1
skouliki's Avatar
Default AD1862 digital supply voltage
Hi.
I've been looking the datasheet of AD1862 and the digital supply can accept voltages that range from +-5v to +-12v.
Does anyone know if there is any performance benefit feeding +-12v to digital supply?
I searched the web and couldnt find an answer
Old 17th July 2013, 11:09 PM   #2
JonSnell Electronic's Avatar
Speed.
If the Digital Chip only has to move 5Volts it it by default 2.2 times faster, due to the slew rate of a chip moving 12Volts.
That is why the fastest domestic memory chips now run at 1.2Volts from 5Volts.
Old 18th July 2013, 12:36 PM   #3
skouliki's Avatar
+-5V it is then.
Thanks Jon for your response
on chip negative voltage regulator with positive supply voltage gvsrkprasad Power Supplies 3 20th February 2013 02:19 PM
PCM63 vs. AD1862 hollowman Digital Source 3 26th March 2008 07:29 PM
another method to set up a digital controlled voltage supply which can provide 0~30V xiaonan Power Supplies 39 4th October 2006 03:21 AM
I want to set up a digital control voltage supply xiaonan Power Supplies 11 7th September 2006 08:31 AM
Is There Still Life For Ad1862 kkchunghk Digital Source 10 7th April 2006 05:15 PM
Copyright 1999-2017 diyAudio
