Digital Crossover/DSP for active speaker with analog and digital input?
Old 10th July 2013, 05:59 PM   #1
Guitarfreak is offline Guitarfreak  Germany
Default Digital Crossover/DSP for active speaker with analog and digital input?
Hello this is Daniel from germany.
For a diy 2-way active speaker project i need an solution for the active crossover.
I would like to build the crossover/dsp into the speaker, so that the speakers work with different preamps.
The features i like to have are:
- digital and analog input
- resolution of 96khz minimum
- IIR and FIR filter possible
- balanced out -> my poweramps have balanced in
Is there some product fitting these requirements?
I thought of the mini sharc at first but it does not support 96khz...
Thank you and best regards
Daniel
Old 12th July 2013, 08:06 AM   #2
curryman is offline curryman  Germany
miniDSP is planning to release a 96kHz plugin for the miniSHARC (however no release date yet). Obviously the higher fs will limit the frequency resolution of the FIR filter stage though, but for two output channels it schould be OK.
Have you seen the new PWR-ICE125 plate amp from miniDSP? It runs with 96kHz samplerate and will also support FIR in the upcoming plugin release. Of course you wouldn't need your amps then (the ICEpower modules are known to perform very well) What I really like is the configuration via WLAN/WIFI (the latter probably through a WIFI router).
Best regards, Daniel (too )
Old 12th July 2013, 10:11 AM   #3
Hello Daniel,
thnaks for the link.
I did not know this - sounds interesting.
But i would like to use analog Poweramps based on TDA7293 found some nice stuff.
I heard about the 96khz plugin, but since there is no release date - i am quite unsure what to think about it.
Best regards
Old 15th July 2013, 07:49 PM   #4
Are there no other DSP out there than the MiniDSP that can manage IIR and FIR?
Best regards
Daniel
Old 16th July 2013, 06:46 AM   #5
Hello Daniel,
the Najda Boards could be an alternative, have a look here. However I didn't follow the thread and don't have detailed info about the actual features (AFAIK IIR + FIR and user selectable Fs 48+96+192kHz).
BTW: the 96kHz plugin for the miniSHARC is going to be released quite soon! See here
Digital Crossover/DSP for active speaker with analog and digital input?Hide this!Advertise here!
High end all digital dsp crossover ? dahlberg Digital Line Level 103 13th March 2014 02:03 AM
Can you use a digital active crossover to design a passive analog crossover ? RickDangerous Digital Line Level 27 1st April 2013 05:59 AM
DSP StudioX: active/digital crossover simulator with features... Under construction. s3tup PC Based 11 22nd November 2012 06:03 PM
digital or analog crossover? maghen Parts 4 10th September 2007 02:26 PM
Need help with a BSS Digital crossover and distortion on unbalanced analog Ken L Multi-Way 4 9th November 2006 01:14 PM
