Help Needed to Read Filter Chip (YM3414) Datasheet - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 9th June 2013, 06:54 PM   #1
Default Help Needed to Read Filter Chip (YM3414) Datasheet
I'm trying to use the YM3414 for a 44.1 kHz asynchronous I2S input. Can this be accomplished by connecting SyncS (pin 15) to X1 (pin 3) so that it receives the same clock signal from the 16.9 MHz (384 fs) oscillator?
Page 6 on the datasheet is where I got the idea. It seems that synchronous inputs require SyncS to be a constant L, but asynchronous inputs appear to require an oscillating SyncS.
The datasheet is attached.
Old 11th June 2013, 04:52 AM   #2
Oops, that would be a constant H for synchronous inputs.
So does SyncS need to be oscillating for asynchronous input or a constant L?
Anyone?
A low cost DIY chip based active filter + Amp circuit needed nareshn Everything Else 5 3rd February 2014 03:57 AM
how to read a datasheet of power amplifier dayanand Class D 5 22nd April 2013 11:28 AM
datasheet YM3404 & YM3414 Bernhard Digital Source 7 20th April 2008 07:44 AM
good chip amp read...... Tsanford Chip Amps 0 28th July 2004 10:32 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
