ADC to IP and IP to DAC
Old 21st May 2013, 07:11 PM   #11
Julf is offline Julf  Europe
Originally Posted by hipro5 View Post
I don't know.
They asked me this - 0 - 65KHz FLAT to IP out and IP in to 0 - 65KHz out.
To do that you need a sample rate of 192 KHz. Will not be easy to find converters to do that. Did they specify maximum allowable latency? Is a lost packet a diaster, or can it be tolerated occasionally?
Old 22nd May 2013, 06:33 AM   #12
hipro5 is offline hipro5
Aren't all or if not all, the majority of the audio cards, 192KHz sampled nowadays?
How high latency is acceptable in audio? I don't know.
I don't think that they want "lost packets" so a bit latency I believe it'll not harm them ehhh?....
Old 22nd May 2013, 10:47 AM   #13
Pretty common on the DAC side, less common on the ADC side.
Problem is that going from 48 KHz to 192 KHz sample rate also quadruples the latency.
If lost packets (resulting in short dropouts) are unacceptable, you will have to buffer enough to allow for retransmissions, so latency could go up into several seconds.
Old 23rd May 2013, 07:49 AM   #14
Several seconds latency?....We are talking here about 20ms with worst case senario of 100ms.
Old 23rd May 2013, 09:01 AM   #15
qusp is offline qusp  Australia
qusp's Avatar
then you cannot have guaranteed buffered data and since you dont have the ability to use the dac as the clock source and send that back, then you have problems. maybe several seconds is overstating it, I dont think you need that much, but certainly 20-100ms is not enough
Old 23rd May 2013, 11:11 AM   #16
DF96 is offline DF96  England
I think the OP needs to go back and tell his musician friends that unless they can find a way to avoid causality and the Nyquist sampling theorem (and perhaps a few more things set for us by the universe as it is) they can't have what they want. It is almost certainly the case that what they want is not actually what they need so maybe if they can spell out exactly what they need, and where they can compromise, an engineering solution may be possible.
Old 23rd May 2013, 12:07 PM   #17
marce is offline marce  United Kingdom
You are getting into real time operating system and data transmission here. It can be done, but the cost would be quite frightening...
Old 23rd May 2013, 01:28 PM   #18
A dedicated Ethernet link could perhaps do it, but you would need to bypass IP and go straight for the physical layer. Not sure if the usual drivers support that, but I suppose you could get a modified driver.
If I recall correctly (I can't be bothered to look it up) a 'thick' Ethernet cable can be up to 500m, and you can have up to three of these connected via bridges? So 1.5km is possible. Remote bridges linked by fibre can extend this. Many years ago I used to play with things like this for the power industry.
Knowledge of the application might help.
Old 23rd May 2013, 02:02 PM   #19
I think (in my mind of course) that things are simple.
An ADC to IP box and an IP to DAC box passing up to 65KHz.
1+1=2
C'mon guys! Help me out to this.
Old 23rd May 2013, 02:05 PM   #20
qusp's Avatar
with your (unreasonable) prerequisites as stated, it is not simple. restating it will not get a different answer
ADC to IP and IP to DACHide this!Advertise here!
IP issues GRollins The Lounge 25 10th July 2007 05:43 AM
DIYZONE and IP Nelson Pass Pass Labs 49 22nd May 2005 04:31 AM
Tcp/ip jaramke Everything Else 5 6th October 2004 04:29 PM
