XMOS DSD 384 kHz / 32bit USB
Old 24th August 2017, 11:00 AM   #881
ghiglie is offline ghiglie  Italy
Originally Posted by yoke View Post
just one picture of AK4490/DRV603/Salas Headamplifier Combo with VFD display
thanks Lyuben
wow! Any picsof PCBs arrangement?
Old 23rd September 2017, 06:03 AM   #882
Maverick2020 is offline Maverick2020  Australia
Anyone have the driver?
Old 23rd September 2017, 07:39 PM   #883
petrovit is offline petrovit  Russian Federation
Which, new? 4.1* ?
Old 4th January 2018, 10:30 AM   #884
kepa1 is offline kepa1  France
Hello,
Newbie question : I have an issue with an XMOS board since I rearranged its setup.
Basically, Foobar (nor JRiver) can't see the unit, because of a driver problem. Uninstalling Foobar and the XMOS driver was unsuccesful.
Still, the USB green led is lit.
Any idea how to make it work again?
Old 4th January 2018, 11:56 AM   #885
Just tried on an old XP laptop, with USB cable plugged in, and got the following message:
"Setup requires that the device is plugged in. Please connect the device you want to install and make sure it is turned on. If your device is currently connected, please unplug and replug it."
Obviously, the issue is hardware...
Old 10th January 2018, 04:30 PM   #886
soroka is offline soroka
Default I2SoverUSB boards quiet clicks
I got board I2SoverUSB boards it works, but there is one unpleasant moment, quiet clicks during playback, especially audible on Hi-res.
I use the card as a USB-to-s/pdif converter .
Checked on different versions of Windows and different computers.
What can you advise?
Old 12th January 2018, 04:30 PM   #887
The request to lay out somewhere firmware is not older than version 3.06.
It is very necessary, in my 3.46 there are occasionally quiet, almost imperceptible clicks.
Thank you.
XMOS DSD 384 kHz / 32bit USBHide this!Advertise here!
DSD Playback system, DSF Player + USB DDC + DSD Amplifier KOON3876 Digital Source 120 14th November 2017 07:25 AM
DSD audio over USB: an XMOS Reference Design implementation sp502 Digital Source 71 30th May 2014 01:06 AM
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
USB to PCM1795 32bit DAC savu Digital Line Level 0 18th April 2012 12:58 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
Resources saved on this page: MySQL 66.67% / PHP 46.24%
