XMOS DSD 384 kHz / 32bit USB - Page 11 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 27th October 2013, 12:10 PM   #101
Can you say Audio?
The draw of the reclocker/dac is less than 130ma, so its Sala is tuned for 150/250. The USB section draws less than 400ma, so it's Salas is tuned for 400/500ma. I usually go with more headroom, but I'm trying hard to control my thermals given my case choice. The ~100ma headroom is proving more than adequate.
Re: tips, you'll definitely want a lytic in C102.
Old 28th October 2013, 09:12 AM   #102
cmiu007 is offline cmiu007  Romania
Old 9th November 2013, 10:25 AM   #103
joro_s is offline joro_s  Bulgaria
Originally Posted by dhbiker View Post
using RaspyFi with my Nokia AC-10E charger with no extra power supply i can say that it works without problems
(Raspberry Model B 512MB RAM)
Thank you for the test. I'm glad that XMOS board works with RaspyFi.
Originally Posted by MisterRogers View Post
Just to share in my efforts; I've got an XMOS/AK stack powered by duel Salas shunts. Both with SILMIC II 220uf lytic, tuning for digital use. Pardon the 'low profile' build pattern; I plan to mount all this in a low profile case.
To the sound - very very nice for the price :-) The reconstruction filter certainly gives up a bit to a traditional IV, but in other ways... Before calling it done, I'm going to add a JG Buffer. Have to say though, the DSD/PCM performance of this stack with quality power is pretty damn good. Thanks again Joro.
Thank you for sharing your efforts with us and for squeezing everything from XMOS/AK combo
Joro
Old 9th November 2013, 10:40 AM   #104
Hi..
Thank you very much joro, the package arrived yesterday, beautifully packed.
Omne question please, the i2s output, which one is which? Can you give me a image showing me how to connectthe board to buffalo3? Also the spdif out, which one should be connected to which .
Sorry for i am a newbie on dac wiring.
Thanks.
Old 10th November 2013, 10:48 AM   #105
Originally Posted by yesman94 View Post
the i2s output, which one is which? Can you give me a image showing me how to connectthe board to buffalo3? Also the spdif out, which one should be connected to which...
You can find the datasheet of the XMOS board at Specifications
As for the connecting, you need to connect the outputs of the XMOS board (pin 13, pin14, pin15 and GND) to the corresponding inputs of Buffalo III board.
It is not necessarily to connect S/PDIF if you already connected XMOS board to Buffalo board through I2S. You can use S/PDIF input of Buffalo for connecting to other sources.
Joro
Old 10th November 2013, 02:56 PM   #106
Thank you very much joro_s
Thats exactly what i need .
I have some dac with ad1865 chip, i might want to buy the board from you one time, but theres something i need to use the money for, for now. . One day maybe hoping the boards will still be able to buy.
Thank you joro_s
Old 10th November 2013, 03:17 PM   #107
Im sorry joro_s,
I missed something,
I want to use it as usb to spdif and usb to i2s, thats possible right? I do not expect all worked at once but i should be able to do it without rewiring right?
Also how to connect the spdif output to rca?
Sorry for my noobness
Thanks.
Old 11th November 2013, 02:43 PM   #108
S/PDIF and I2S are working simultaneously up to 192kHz.
As for S/PDIF connection you can choose the pin above the label "out S/PDIF" for signal.
Joro
Old 13th November 2013, 12:31 PM   #109
gugi100 is offline gugi100  Netherlands
Hi Joro,
I now have the usb / 4396 combo running on a separated PS based on LM 317. The usb is now running on 4.3 V and the reclock / 4396 board is running on 5.2 V.
The sound is very good.
The question i have is: Is it usefull to try to improve the PS for the reclock / 4396 board anyfuther?
The clocks are locally regulated (LP59000?) how is the regulation around the 4396?
I think EUR 63 for the usb xmos board with isolation and reclocking is a real bargain!
Gr GJ
Old 13th November 2013, 01:12 PM   #110
Can you say Audio?
I'll share my experience gugi; I started out powering USB/AK each with 317's on the bench. It sounded pretty good. I had a couple of extra BIB's, so I built a couple of shunts to replace them. A definite improvement. More slam, more dynamic, better pace.
Just be sure to use lytics in your shunts if you go that way. I've found the Elna Silmic II's to be stellar with the BIB's built to power digital circuits.
DSD audio over USB: an XMOS Reference Design implementation sp502 Digital Source 71 30th May 2014 02:06 AM
DSD Playback system, DSF Player + USB DDC + DSD Amplifier KOON3876 Digital Source 116 5th September 2012 12:20 AM
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
USB to PCM1795 32bit DAC savu Digital Line Level 0 18th April 2012 01:58 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
Copyright 1999-2017 diyAudio
