Najda builds - resource list - Page 2 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 5th May 2013, 10:47 AM   #11
SAC is offline SAC  United Kingdom
Hi Raj, thanks for contributing.
That supply datasheet says over voltage protection is set at 6.2V. The Nadja is only tolerant to 5.5V though. Could be a problem!?
"All 5-Volt outputs include
build-in OVP as standard
(setting is 6.2 V Ī0.4 V)"
Old 9th May 2013, 05:09 PM   #12
dahlberg's Avatar
Cad (dxf)file for the backpanel.
http://www.dahlbergaudiodesign.se/najda_back.zip
Old 16th May 2013, 06:51 AM   #13
r1968 is offline r1968  United States
Default 8 LED Module
Would this work for the status LED's?
8 x LEDs Module
--raj
Old 16th May 2013, 07:46 AM   #14
Please keep questions in the original thread, this thread is just a list for successfully used equipment to be added.
DSP Xover project (part 2)
Old 23rd December 2013, 11:21 AM   #15
The rotary volume control function is detailed here;
requires "2x 10 kOhms pullups and 2x 100 nF debounce caps"
Old 30th December 2013, 01:00 PM   #16
JLOP is offline JLOP  France
Default Crimp connectors housing and Pre-crimped cables
Hi all
I did a lot unsuccessful research to find a modular system with
- all kind of 1xN and 2xM connectors required to integrate Najda and WaveIO boards
- long length (60cm) pre-crimped cables, as most often Dupont cable are available only in 20 to 30, maximum 40 cm
- multi-color cables which makes much more easy to install
until I found out Pololu - Crimp Connector Housings where they have all cables and housing. Order is being handled, will tell if not ok.
Hope that helps
BR
Jean-Louis
Old 2nd February 2014, 08:04 PM   #17
An expansion board is in the works;
"I'm also working on the expansion board, it will have an additional symmetric analog input and 2 additional analog outs."
Old 9th May 2014, 07:32 AM   #18
Hi! Do you have a pocture or PDF how it looks like? Sorry, I don't have CAD.
Mike
Old 23rd January 2015, 09:17 AM   #19
Originally Posted by r1968 View Post
Hi SAC
This thread will become a wonderful resource as Najda matures.
Want to add one power supply that is plentiful in Ebay US site for around $40 new. Specs look good for the SLT series.
http://www.emersonindustrial.com/en-...ut-Linears.pdf
--raj
I have bought the Sola SLT12-40204-12T but it didn't work out.
You have to watch out for the type of housing. The H2 does not have the -12V/GND/+12V output the Najda needs.. It has 2x +12V outputs.
The H1 housing does have the correct outputs (1x 5V and the +12v/gnd/-12V)
Old 16th September 2015, 06:20 AM   #20
Folks, will this be a feasible USB audio interface for Najda
XMOS DSD 384 kHz / 32bit USB
offcial site
I2SoverUSB - I2S over USB Audio
WAF Audio Najda reviews RickDangerous Multi-Way 5 2nd September 2016 02:09 PM
031612 Car Audio Installation Product List- PLEASE REVIEW THIS LIST! Need help! gordonfreeman Car Audio 1 18th March 2012 01:27 AM
031612 Car Audio Installation Product List- PLEASE REVIEW THIS LIST! Need help! gordonfreeman Parts 0 17th March 2012 07:03 AM
great resource! yardcat Introductions 2 3rd December 2008 01:38 AM
Need this chip youíre my last resource Hayden Parts 2 2nd February 2005 10:46 AM
Copyright ©1999-2017 diyAudio
