Cheapest top dac?
Cheapest top dac?
Old 2nd May 2013, 04:34 AM   #41
luxury54 is offline luxury54  Romania
ok thanks for your answer, you convinced me and I will order some 6DJ8 tubes for experiments, this might be fun;
so my last question would be (although you may repeat yourself), but I just want to be sure - that means in your current layout, NO I/V resistor from the (-) phase goes to ground and there is only one single 120 ohm resistor from the (+) phase that goes to GND? this means that the (-) phase is tied up directly to the GRID of the valve without any I/V resistor?
thanks in advance
p.s. I followed the link in your signature and your projects look awesome, very clean work and nice external enclosure designs
== There are no limitations to the self except those you believe in ==
Old 2nd May 2013, 08:04 AM   #42
McGyver is offline McGyver  Poland
McGyver's Avatar
No, each signal phase is loaded by I/V resistor to ground.
Old 2nd May 2013, 08:18 AM   #43
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
Lampizator - High End Lampizator Kit ver 3.0
I still have it and it sounds wonderful and i use CS4398 dac.
Old 2nd May 2013, 08:22 AM   #44
McGyver's Avatar
Where is a schematics for this lampizator kit?
Old 2nd May 2013, 12:53 PM   #45
Starre is offline Starre  Sweden
I feel dubious about getting that kit, no way I can hear it before buying .
Old 2nd May 2013, 04:25 PM   #46
the schematics must have been here at the end but maybe intentionally left empty
http://www.lampizator.eu/shop/Manual...al%206N16P.pdf
but if he says that is the same kit like v2 with some upgrades only in the power supply part that means it has to be the same like at the end of this other pdf
http://www.lampizator.eu/shop/Manual...ual%20V2,0.pdf
but if you say that this multi purpose SRPP sounds worse than a cathode follower then I take your word for it;
but I found some very cheap NOS miniature tubes 6N16P (10 pieces for 15$)in my country that I will also try in this SRPP config and I will compare the sound - this is the fun in all these DIY projects hehe
edit:
anyway, I see that lampizator's scheme posted at the end of v2 pdf document differs somehow from the first one posted by me at post No.#39 in this thread, .... he takes the OUT signal from the GRID of the second half of the triode ??
Old 2nd May 2013, 04:50 PM   #47
McGyver's Avatar
I say SRPP sounds worse than common cathode tied to cathode follower in my system.
Yes, you can also use 6N16B to build common cathode tied to cathode follower.
edit:
It's SRPP, but there's a mistake in drawing or mistake in project. One may take the OUT signal from grid and it works, but output resistance of such circuit is very huge and it can drive in practice only grid of other tube.
Old 3rd May 2013, 03:21 AM   #48
do you have an idea what component values might be changed in case of using this 6N16P in your schematic as cathode follower configuration instead of SRPP?
Old 3rd May 2013, 03:39 AM   #49
optimationman is offline optimationman  United States
Talking ready to go dac
try a denon dvd-5000/9000 for little money. I have bought both for less than $100 and would challenge anyone to get better for less. Both had reading problems, but not the lazer, and the unit is well built and cannot be bettered for the money. This is only good info if you are interested in good value.
Old 27th June 2013, 09:53 AM   #50
Anybody with experience from Meitner MA-1 dac? Seems interesting, can do DSD, dac only.
Cheapest top dac?Hide this!Advertise here!
top end Twisted Pair dac Rafal Twisted Pear 3 31st August 2010 05:29 AM
Cheapest USB DAC kit? Spasticteapot Digital Source 0 16th November 2006 04:56 AM
Top-notch DAC. Hajime Digital Source 86 30th June 2004 08:07 AM
Top Notch Dac Kit ad010685 Digital Source 2 29th June 2003 10:56 PM
