DCX2496 XO phase response oddities - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 13th April 2013, 08:01 AM   #1
wxn is offline wxn  Lithuania
wxn's Avatar
Default DCX2496 XO phase response oddities
So everybody is saying that DCX has the same phase response as analog filter. Well I measured it and it is simply not true - take a look at the pictures.
HP filter does seem to act somewhat "textbooky" but the LP does not, it seems to be far more linear at the crossover frequency. I've tested this in various configurations and this tendency does not depend on frequency (100Hz and 1Hz illustrated) or filter type (LR48 shown for more clarity).
Anyone got an explanation for this and perhaps a way to overcome or compensate for this strange phase behavior?
Nothing is as simple as it seems
Old 13th April 2013, 03:29 PM   #2
Davey is online now Davey  United States
Your measurement scheme is incorrect. You need to discount the latency of the unit when evaluating phase response.
The easiest way to view phase response is to use one output channel of the DCX with zero programming applied as your reference channel and then measure relative to that with your other channel in a differential scheme.
I guarantee you'll then see phase response identical to an analog equivalent filter.
Dave.
Old 13th April 2013, 03:55 PM   #3
Pano is offline Pano  United States
Pano's Avatar
WXN,I agree with the above. I've done DCX measurements using HOLMImpulse and the transfer functions were pretty much textbook. Take a look at latency. HOLMImpulse can manage that for you, if you don't have another way to do it.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 13th April 2013, 04:20 PM   #4
WXN-
Since you are measuring the DCX can you do me a favor and measure some EQ bands with a couple values of Q and equal amounts of boost and cut dB?
For instance, can you measure EQ centered on 1000Hz (any frequency is OK, but keep it constant) for:
Q=1 gain = +6dB
Q=1 gain = -6dB
Q=4 gain = +6dB
Q=4 gain = -6dB
Also, can you measure the output with two bands on the same channel that have the same Fo, Q, and gain magnitude but have +gain and -gain, like this:
EQ1: Fo=1kHz, Q=1, -6dB
EQ1: Fo=1kHz, Q=1, +6dB
measure the output = EQ1 + EQ2
I want to see if the bands cancel and the output is "flat" (or not).
Can you post the results here?
If anyone else can do it, or knows the behavior of the EQ bands for the DCX, please post. Thanks,
-Charlie
Old 13th April 2013, 06:43 PM   #5
wxn's Avatar
Ok, thanks guys, that was enlightening! I'll post the measurements Charlie asked in a minute
Old 13th April 2013, 07:01 PM   #6
wxn's Avatar
Here are the graphs, no smoothing. Please ignore the wiggly baseline, it's caused by the aging EQ in my mixer.
The EQ1+EQ2 curve does seem to be pretty much identical to the baseline.
There is a peak at 1kHz and its harmonics present in all of these curves, not sure about its origins.
Old 13th April 2013, 08:02 PM   #7
Charlie is asking for the "definition of bandwidth" for the Q settings of the DCX2496. Here's a measurement of Q=1 and Q=4 for a 1khz notch filter -6db. (The +6db measurements are exactly opposite of these as expected.)
The second measurement you asked for yields a perfectly flat response.......as expected.
Dave.
Old 13th April 2013, 08:20 PM   #8
Dave.
Dave - thanks for posting that. I've been able to check this against a new version of the Active Crossover Designer that I have been working up.
These EQ bands are "symmetrical", which is not the same as what you get when you design an analog EQ stage (one with negative gain at least).
The phase looks right to me (in response to O/P).
-Charlie
Old 13th April 2013, 09:27 PM   #9
wxn's Avatar
Not to be picky but what exactly did I do wrong this time? It's exactly the same, except for different scale...
Old 13th April 2013, 09:33 PM   #10
You didn't do anything wrong... Dave just posted a very clear plot without the funny skew. I needed to read off some values to compare with some of my own results and his plot worked well for me for that purpose.
Thanks for checking that the bands cancel. I needed to have that confirmed.
-Charlie
DCX2496 XO advice for a noob. Docks Multi-Way 5 25th August 2011 09:52 PM
DCX2496 or Moamps XO ???? george a Digital Line Level 0 5th December 2004 10:35 AM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
Is a series-XO the only way to always have both speakers in phase? Bricolo Multi-Way 11 31st March 2003 08:40 AM
Proac Response 2.5 active xo tiroth Multi-Way 13 26th December 2002 04:24 PM
Copyright 1999-2017 diyAudio
