Raspberry Pi I2S output as Asynchronous USB-to-I2S - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 26th August 2013, 05:54 AM   #21
tjaekel is offline tjaekel  United States
Default I2S audiophile DAC, works also on Raspberry Pi
My T-DAC, with MCP1794, quite audiophile quality, works.
I can use also on Raspberry Pi, even the intention is to use with XMOS or a XynergyXS FPGA board as standalone DAC.
T-DAC and RPi-DAC - High Quality DAC
Old 18th September 2013, 10:37 AM   #22
PM sent tjaekel
Old 22nd September 2013, 11:41 AM   #23
pinnocchio's Avatar
Did you ever released the Rpi-DAC as full project for sale tjaekel?
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA2 | TSSA | Telos 390 Clone | NX Amp | FH9hv
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 23rd September 2013, 05:19 PM   #24
Hi Pinnocchio,
I am in the process to clarify export policies and to find partner company to let it manufacture (assemble, solder). To send you an empty PCB without any parts would be possible (w/o any parts), as complete equipped board still some legal issues to clarify.
I'll keep you posted when I have a solution.
Best regards
Torsten
Old 26th September 2013, 11:11 AM   #25
Just like to thank Torsten for dispatching a board for evaluation and going above and beyond to help out!
Old 26th September 2013, 11:57 AM   #26
Heffa is offline Heffa  Sweden
Heffa's Avatar
I second that!
Received my RPi-DAC board yesterday, and am looking forward to start building it.
I probably need to get me a better solder station though, the LDO's are TINY
Old 27th September 2013, 03:18 AM   #27
Good luck and have fun.
Yes, the LDOs are tiny and tricky (I am also fighting again with those, for a rev. 2 board).
Suggestion:
If you can provide all the voltages (3.3V, 100mA, 5.0V, 100mA without RPi, +15V, 1.4A, -15V, 1.4A) then you can skip the LDOs and provide directly.
Just a question how many hum your power supply will generate (the LDOs are great).
There is a lot of room to optimize, including to use another PSU solution (idea was to need just a transformer and all is aboard).
Actually, you would need a heat gun. Soldering manually works fine with magnifying glass and very thin tip.
I am looking for a partner to do the soldering and to manufacture. If anybody could help ... highly appreciated.
Best regards
Torsten
Originally Posted by Heffa View Post
I second that!
exaU2I - Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 1373 13th January 2017 06:45 AM
XMOS-based Asynchronous USB to I2S interface Lorien Digital Line Level 3007 7th January 2017 02:57 PM
LPC3130 for asynchronous USB to I2S jonsmirl Digital Line Level 16 11th November 2012 02:12 AM
Copyright 1999-2017 diyAudio
