Build thread for ES9023 + JG Buffer boards (betatest)
Old 30th March 2013, 08:07 AM   #41
grufti is offline grufti  United States
grufti's Avatar
Nice!
I'm still listening to music on the test setup, having fun with it.
Old 30th March 2013, 08:09 AM   #42
grufti's Avatar
What about the charge pump cap[s]? I like the new XO placement a lot. I also like the now missing optional C103/C104 as you can tell from my beta build.
Old 30th March 2013, 08:26 PM   #43
enjoybiking is offline enjoybiking  United States
Default What Charge Pump? [kidding]
I did it! I have -3.4V on the ES9023 NEG pin, no charge-pump cap. I do not have anything but a VOM handy so I hesitate to tweak the -V any more than I have. The SOUND? As good or better than before I started, and that is with no filtering on the POT wiper {yet}
9V battery [8.something] --> 79L05 --> 100R multi-turn POT, wiper set under load to -3.4Vdc [my prior NEG with +3.6 source and 100K to GND on ES9026 pin #6]
From this experience I would say it is worth determining what is the best negative voltage to place there. Now, mind you, my UAE23 device under test has 100K ohms on the Vreg pin ES9023 pin #6 to ground -- I could remove THAT however that is something I pretty much like, not having tried ESS suggestion of 130K or ODAC value of 118K there [100K is what I had when I did it].
SO that is another test yet to consider, a temporary POT {wired as variable R} and fixed-R on ES9023 pin #6 to ground so could have say 75K--200K test range. Test with a very "hot" recording like a female vocalist up close on the microphone example Musica Nuda.
I am currently playing The Bridge by Jens KrÜger and it sounds superb. The FET tester is not getting it's 9V back anytime soon
Old 30th March 2013, 09:47 PM   #44
curryman is offline curryman  Germany
Since it turned out () that a suitable pad layout for the ES9023 was not available I made a new one. Some pads are a little bit longer in order to put Cs directly at the pins For the charge pump 1-2.2µF X7R (0402 or 0603) is perfectly suited.
Have a look at the layout for the XO decoupling and grounding. The small cap C22 for local decoupling (10nF COG/NPO) is as close a possible to VDD. GND is routed with a low impedance trace to the Cap. Note that only the bigger cap C2 (e.g. 2.2µF) is connected to the groundplane. The XO will draw current during rising or trailing edge. This will be delivered only from C22 (C2 is too slow and too far away) and thus the current will flow from C22 through the XO and back to C22. All the noise will stay there and not affect the main ground! I used the same layout for the flipflops
I omitted the TH foil caps (103, 104) since I am convinced that the SMD PPS caps are really good here and this gave some more room for improvements on the lower board area
BTW: I will clean the part numbering for the final version (e.g. order part numbers according to placement within schematic). Still a lot of work...
Have fun!
Old 30th March 2013, 10:54 PM   #45
As to the charge-pump and noise, as I told Daniel in another thread, I'll try and look for the prior noise he saw on the NEG pin around 1.5MHz...{amplitude unknown} Daniel expects there could be CP-related noise yet, with CP cap missing and NEG fed with -3.4Vdc. Only one way to tell, I have to look. I tried to Google charge-pump circuits and found "too many". I can only guess what is inside ES9023. I had another odd thought, not knowing the circuit inside....could I use a cap to ground on one or both of the CP pins I depopulated for the external NEG test? SWAMP it? 100R to GND? It's only a test and a crude one. I have a stack of SMD caps on the NEG pin to ground, ok, some mm away, I COULD make a very short path NEG --||--GND top-side on the UAE23 [another model of ES9023-based DAC sold on eBAy]. Maybe 0.01uF? .1? I can haul a scope up to the living room but maybe not on a Saturday evening, I've come too far not to get an answer as to the nature of the NEG pin and noise.
Old 30th March 2013, 11:20 PM   #46
grufti's Avatar
Good reasons to drop C103, C104. I had noticed the close proximity of C2, C22. That sounds like a good way to go, possibly even overkill, but that would not hurt. The longer pads around the ES9023 are a neat idea. I can't wait to try that version.
One additional question: how about moving the u.fl for MCLK closer to the ES9023 into the left part of the open space above the three other u.fl connectors? They don't really need to be in one line and that way the distance to the XO / ES9023 would be even shorter.
Old 30th March 2013, 11:52 PM   #47
Ferrite bead in series to V+ to OSC? Should I2s lines have same length if MCK is used? {USB receiver}. I LOVE the new custom ES9023 pads!! Would ES9023 benefit in any way from a ground plate on top of it as shown in ES9018 thread? A swatch of copper foil and some GND pads to tack it to topside?
Old 31st March 2013, 08:27 AM   #48
Don't think that C2 + C22 are overkill. You'll need a fast cap (e.g. <100nF) to serve the current need of the XO (3ns rise time -> 333MHz + harmonics up to GHz!) and with this small cap the reg will not be stable (at least MIC needs some ESR as you also mentioned -> Tantal). Also reg is much too slow to reload the small cap between the transitions.
Moving the u.fl is an option that i will check. Please note that I designed the traces for the I2S lines to have 50Ohm impedance (trace thickness, gap between trace and GND, board thickness,...) so the lenght of the trace will only add some (minor) damping. BTW: if you don't need the external MCLK you should cut the trace close to the ES9023 to avoid reflections
Ferrite beads together with close Cs are used to clean power just before the reg and to prevent dirt e.g. coming from the XO to spread to other parts (the reg is "open" for HF). Frequencies on I2S lines are still quite low (<< GHz) so the same length should not be necessary here. Impedance is more important. GND isn't routed yet and will be also on top layer under ES9023. Though directly on board and not using a copper foil Thats a point I am just thinking over anyway: the routing of VDD to mute pin. This might be reworked...
Old 31st March 2013, 05:57 PM   #49
grufti's Avatar
It's always difficult to communicate glitch free on a forum like this. I didn't mean to suggest overkill. I really like the C2 , C22 arrangement as proposed. As far as I can tell it could handle frequencies many times higher than the ones we're dealing with here. That's where the idea came in.
Old 31st March 2013, 06:08 PM   #50
Everythings OK, just wanted to explain a bit what may be obvious to most of us here but perhaps not to all
Build thread for ES9023 + JG Buffer boards (betatest)Hide this!Advertise here!
Fastron Inductor Group Buy for JG Filter Buffer pchw Group Buys 176 8th February 2013 09:19 PM
ES9023 DAC build heartwinter Vendor's Bazaar 8 7th July 2012 09:27 AM
Preamp / buffer suggestions for TA2020 / TA2024 boards lossfound Class D 11 29th January 2012 10:35 AM
ES9023 and buffer before 10K pot. Neutrality Digital Line Level 1 12th December 2011 07:00 PM
DIY Op Amp Buffer Boards aziltz Swap Meet 20 18th October 2011 12:35 AM
