| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I finished project of the PCB for ES9023 Sabre DAC. PCB is compatibile with my USB-I2S converter (TAS1020 based,asynchronous, low jitter XOs, galwanic isolation ADUM3160). More info about converter is here: TAS1020B-based Asynchronous USB to I2S/SPDIF converter 24bit/96kHz - DAC can work with own 50MHz oscillator or synchronous witch MCLK from USB-I2S converter. - Critical elements (capacitors) can be mounted THT or SMD. - I2S connector is Pin2Pin compatibile with converter - Boards can be stacked Today I sent the board into production. Prototype series (10pcs) will be available in about 2 weeks. Best regards, JarekC |
| Hifimediy ES9023+TE7022 24/96 USB Dac | sharpi31 | Digital Line Level | 309 | 11th June 2013 11:01 AM |
| TAS1020B-based Asynchronous USB to I2S/SPDIF converter 24bit/96kHz | JarekC | Digital Source | 108 | 12th May 2013 02:08 AM |
| Bragi, an Asynchronous ES9023 DAC with isolated I2S Input and Alps RK27 Volume pot | Neutrality | Digital Line Level | 36 | 24th November 2012 12:18 PM |
| USB input for DAC | denny9167 | Digital Line Level | 1 | 24th January 2010 12:53 AM |
| Cheap Asynchronous USB | jkeny | Digital Line Level | 5 | 26th September 2009 11:24 AM |
