AKM AK4399 DAC PCB+IC on Ebay - Page 8 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st March 2013, 05:25 AM   #71
Old 23rd March 2013, 09:20 AM   #72
Originally Posted by KlipschKid View Post
I think you're right - the re-clock means the quality of the cm is not so critical, so no need to upgrade resistors to thin film for this use.
Yes, 5534 sound good ! 627 are one of my favourite op amps. But for my headphone use, the 827 gave the best sound balance.
I look forward to seeing the new CM ! I hope you do one with an ES9023 dac ic. it's amazingly good for such a cheap IC, especially with a 50mhz saw oscillator as mclk.
the source is absolute critical, reclock can help but also add noise/jitter etc. Mostly, I think good source is better than reclock of a bad source. The new usb i2s is based on another famous chipset cm 44.1 and 48 bck is work at 128x lrck, es9018 like bck = 64x lrck and the universal shifter of my latest toy nos dac also need 64x lrck ...although 32bit i2s need bck = 128x lrck but there are not 32bit cd
USB has requirment on D+/D- trace impendence,
http://www.usb.org/developers/docs/hs_usb_pdg_r1_0.pdf
Old 28th March 2013, 08:26 PM   #73
MBA is offline MBA  Czech Republic
It looks like the board follows the EVM circuit. Is there an easy possibility to connect a balanced power amp directly? How must the output be modified?
@diyinhk: are there any board modifications planned (regarding routing, regs, USB module pins etc.) in the near future?
Mike
Old 30th March 2013, 11:00 AM   #74
Hi
Do you have the schematic of the AK4399 board ?
Serge
Old 1st April 2013, 03:59 PM   #75
@Serge: look for the AK4399 evaluation module schematics at AKM - I suppose it is the same.
Old 31st May 2013, 05:14 PM   #76
Page.P is offline Page.P  Czech Republic
AK4399 has been deleted from AKM website :-(
Old 1st June 2013, 02:32 AM   #77
Here is datasheet. http://myl8test.files.wordpress.com/...k4399_f03e.pdf
Old 1st June 2013, 08:57 AM   #78
Thank you, I have one. But on AKM website there are no informations for this DAC. Hope it has not been canceled and it is only mistake!
Old 4th November 2013, 11:53 AM   #79
AK4399EQ | Product | AKM - Asahi Kasei Microdevices
Old 8th January 2014, 04:26 PM   #80
burninggecko's Avatar
Has anyone tried to run two run two of these boards in dual mono? I emailed the supplier at diyinhk and he replied that it is possible since the pcb has all the pin routes out. I just wanted to see if anyone has actually tried this and any advice / feedback.
Todd
Is it a good idea to start a DAC wih AK4399 Sergelisses Digital Line Level 14 4th June 2013 04:30 AM
Russian 1543 dac pcb on ebay PreSapian Digital Line Level 10 1st November 2012 06:06 PM
AK4399 123dB 32Bit DAC wizard1238 Digital Line Level 10 12th September 2012 02:36 PM
help with this AKM dac, please federico moreno Digital Source 8 27th July 2006 08:59 PM
Copyright 1999-2017 diyAudio
