Hacked TDA1541 CD Player USB DAC Idea
Old 23rd April 2013, 04:28 PM   #31
themartianboy is offline themartianboy  Canada
Originally Posted by oshifis View Post
The eBay seller informed me that the I2S output is 44.1 kHz 16-bit. So probably the coax and optical output (not implemented on my unit) can go up to 96 kHz 24-bit.
Interesting. I wonder then why I wasn't successful in connecting to the I2S input of the YM3414. I thought it was because the signal was coming in 24 bit "words".
Old 23rd April 2013, 06:17 PM   #32
lcsaszar is offline lcsaszar  Hungary
Default 16-bit 44.1 kHz data stream
Upper trace: DATA
Lower trace: LRCK (44.1 kHz stretched to full scale)
fSCLK = 64 x fLRCK
Old 25th April 2013, 01:02 PM   #33
Might there be a problem with my unit? I read the I2S Bus specification from Philips, and it says the WS line changes one clock period before the MSB is transmitted. However on the oscilloscope screenshot above the MSB is transmitted several clock periods after the WS edge. I suppose the receiver TDA1541A expects the MSB according to the I2S spec, but it gets zeros for 3 or 4 clock periods, then it comes the real MSB (let's call it Bit15), which it interprets as Bit12 or Bit11, and the analog signal is attenuated accordingly by 8 or 16.
Old 25th April 2013, 08:25 PM   #34
Maybe there is a problem with your USB unit? I wish I could give you more ideas but I can see that you are more advanced in electronics that I am. All I can say is that I connected the I2S signal from the converter board directly to the I2S inputs on both a TDA1541 and a TDA1541A with no problems. The only other thing I can think of to make sure the proper mode is selected with pin 27 on the TDA1541A.
Hopefully someone else with more knowledge can join the thread...
Old 26th April 2013, 06:17 PM   #35
Default Problem solved
I installed the TeraLink-X2 driver, and the USB to I2S converter works properly
Old 26th April 2013, 06:37 PM   #36
That's great! Are you going to do any modifications to the converter board and/or the CD player board?
Old 27th April 2013, 05:59 PM   #37
I am happy with my new toy for now
The CD player board is a testbed only for trying some mods that I would transfer to my actual CD player if they work (like DEM clock mods etc.)
Old 1st May 2013, 10:10 PM   #38
I'd be interested in knowing how those mod tests go. Feel free to post your findings here.
Old 7th August 2014, 11:00 AM   #39
hollowman is online now hollowman  United States
hollowman's Avatar
So I've gotta bunch of classic Philips CD players, with their internal TDA1541A, TDA1545A and TDA1543 DAC beggin' to return to their glory days...
...and along comes a POTENTIAL $23.00 USD solution from HK/China's nutsaudio.com ...
SPECS:
24/96 USB > SPDIF + ANALOG TE7022 + I2S CONVERTER for DAC
ALREADY ASSEMBLED
Input voltage : AC 9V or DC 8~13V or by USB
PCB Size : 80mm x 40mm
D/A chip: N/A
USB : Chip : TE7022L
Digital inputs: 1 X USB
Outputs: ANALOG - not available , DIGITAL - RCA + I2S
Methinks this is the same board posted way back on page 1 of this thread ... IAC... what do you folks think?Are they really nuts ... or might sticking the board above into a Philips CD-650 be an interesting experiment? Anyone tried this (or similar board, breadboard DIY or China kit)?
"I got banned from a Hi-Fi forum. And I liked it."
- Luv, Katy "Hollowman" Perry
Old 7th August 2014, 01:16 PM   #40
This is the very same board I also have. I soldered the I2S output wires to the holes, but not installed it into the CD player. It works with a PCB that is removed from a Philips CD player.
Hacked TDA1541 CD Player USB DAC IdeaHide this!Advertise here!
Reclocking in a TDA1541 (zero-oversampling) CD player Dr.H Digital Source 13 4th June 2010 07:35 AM
FS: TDA1541 twin DAC, USB/I2S receiver, more nl Swap Meet 6 30th April 2010 09:02 PM
TDA1541 CD Player for Non-Oversampling lovekylie Digital Line Level 10 29th July 2007 07:31 PM
Using a CD player -AS- a DAC, via USB... rja Digital Source 5 19th April 2007 01:20 AM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 08:12 PM
