Hacked TDA1541 CD Player USB DAC Idea
Old 25th March 2013, 10:48 PM   #11
s3tup is offline s3tup
s3tup's Avatar
Shouldnt work with YM, it wants 384Fs MCLK, but Tenor AFAIK supplies 256Fs.
Bypass YM (don't break it, just cut traces between YM and TDA), feed TDA from Tenor.
This way you loose rather nice digital filter... uh... and go rather creepy route of NOS /some may argue, so i'll tag it "IMHO"/
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 25th March 2013, 11:43 PM   #12
themartianboy is offline themartianboy  Canada
Originally Posted by AudioLapDance View Post
Good job so far!
It sound like you might be sending the 1541 24 bits worth of data and it can only accept 16 bits so the resulting waveform is "too loud"
Are you able to change the bit depth (16, 24 bit) and rate (44, 48, 96, 192 ...)?
I am using iTunes on an old PowerPC based Mac running OS 10.4. I played a CD and 16/44.1 AIFF files with the same result. Is it possible that iTunes is sending 24 bits?
Old 25th March 2013, 11:51 PM   #13
Please correct me if I'm wrong (which I probably am), but I got the impression that the YM would be happy with anything 16/44.1 that got sent its way since it has its own clocking from an oscillator on the PCB and doesn't require an MCLK signal.
Old 26th March 2013, 01:02 AM   #14
I think that the middle of page 6 of the YM3414 datasheet supports what I was saying about using an asynchronous input. But then SyncS should be "L". On the CD player it is currently set to "H".
Old 26th March 2013, 11:14 AM   #15
lcsaszar is offline lcsaszar  Hungary
I am about to buy the same board with I2S output. Is it transparent, meaning if I play 16-bit/44.1kHz WAV file on my PC and send it to the USB, will the board send the same bit resolution and bitrate to the I2S pins? Also does Windows XP recognize the board as external USB DAC? Finally, what is the function of the little switch? Thanks.
Old 26th March 2013, 03:56 PM   #16
Those are good questions. The little switch is for switching between USB power and an external power source. I'm not sure about Windows XP specifically, but I can tell you that it is a USB audio class 1 device. As for transparency, I have no idea. Maybe somebody else has the answer to that?
Old 26th March 2013, 06:56 PM   #17
josha is offline josha  United Kingdom
Hi there,
If you bypass the filter, you may have to reroute pin27 of the tda1541 also. On your cdp it's connected to - 5v, IIRC on the saa7220 based players it was connected to +5v. I MIGHT BE WRONG!! (check the data sheet!) This pin sets the input mode of the tda to accept different formats
-5v is simultaneous mode whereas +5v is TWC, I think you need twc if you go direct. Apologies, writing this on a phone so no access to the data sheets!
Old 27th March 2013, 12:29 AM   #18
Originally Posted by josha View Post
Hi there,
I would agree if I was going directly into the TDA1541A. But I was thinking that if I have to resort to bypassing the filter chip, I could do it right at the output of the filter, and take advantage of the circuit that appears to reclock (?) and split the signal into left and right channels. Then, I believe, I don't need to change the H/L value at pin27.
Old 27th March 2013, 03:00 AM   #19
Hi there,
Oh man, you're totally right. I thought the filter chip was outputting an I2S signal, but it's not.
Old 27th March 2013, 05:19 PM   #20
I gave up on running it through the filter. I patched it directly into a TDA1541 in another old CD player with tube output stage for some NOS action. It sounds decent, but not yet as good as from the CD player's transport. I'm hoping that an external power upgrade will help.
Somewhere on this forum I once read that the TE7022 relays information in 24/96 format, even when receiving 16/44.1 data. I suspect that this is true, and that's why I was having trouble patching into the YM3414 filter chip, which seems to require 16 bit "words". (Apparently the TDA1541 is friendlier to 24 bit data, simply ignoring the last 8 bits.)
If you are looking for 16 bit, JarekC makes a board that he can configured to send in 16 bits. I'm not sure if it's "transparent" with respect to sampling frequency though.
TAS1020B-based Asynchronous USB to I2S/SPDIF converter 24bit/96kHz
Hacked TDA1541 CD Player USB DAC IdeaHide this!Advertise here!
Reclocking in a TDA1541 (zero-oversampling) CD player Dr.H Digital Source 13 4th June 2010 07:35 AM
FS: TDA1541 twin DAC, USB/I2S receiver, more nl Swap Meet 6 30th April 2010 09:02 PM
TDA1541 CD Player for Non-Oversampling lovekylie Digital Line Level 10 29th July 2007 07:31 PM
Using a CD player -AS- a DAC, via USB... rja Digital Source 5 19th April 2007 01:20 AM
Wanted: Leftover DAC from an upgraded CD player, or CD player with broken transport. Spasticteapot Swap Meet 0 7th October 2006 08:12 PM
