Using the AD844 as an I/V - Page 25 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st February 2013, 12:16 AM   #241
I don't think you'd "hear" the difference of that filter--it's effect at audio freq would be minimal.
What it's probably doing is changing the loading of the AD844 or the increase in high freq is affecting something down chain. Something strange and technical no doubt! I'll sim it up for ya later tonight!
Gotta go play with me' boy!
Jeff
PS Filters are weirdass, what freq is your 3rd order at? It could be interacting with that 100k ...
Old 21st February 2013, 12:35 AM   #242
georgehifi's Avatar
Send a message via MSN to georgehifi
Thanks Jeff, but I have my doubts whether siming it will show anything, as I think it's a stability issue only under musical dynamic conditions. As it looks perfectly stable on the crow with all test waves either way. I believe the 570pf is sending it into slight ringing, as audibly it 's giving the opposite to what you would expect, sweeter without the cap. And I forgot to mention with the 560pf capthe DC offset absolutly stable to within .5mV Without the cap it can wander just a touch more, still very good.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 21st February 2013, 02:26 AM   #243
PCM1704: current output DAC, dual mono, single ended, 1.2 mA full scale current, 0V reference voltage. I'm not sure how much current offset it has but I left it as 2mA and cancelled it with the external current source (IS1 2mA).
2.7k with 560pf and 1pf
Actually I take it back, maybe this would affect high freqs ...
Old 21st February 2013, 03:03 AM   #244
300Hz square wave
Old 21st February 2013, 03:11 AM   #245
georgehifi's Avatar
Attachment 331768
Thanks Jeff.
I take it
The brown in both graphs is 2.7k no cap
The red in the top graph is 2.7k with 1pf
The green in the lower graph is 2.7k with 560pf
I also noted that your taking the output from pin 6 and not pin 5?
Cheers George
Old 21st February 2013, 03:16 AM   #246
georgehifi's Avatar
Sorry I understand now ones gain and the other is pahase angle.
Cheers George
Old 21st February 2013, 03:23 AM   #247
georgehifi's Avatar
So yes with the 560pf cap I hear a tad more forwardness in the highs, which gives a change in phase angle from 5k> and it's this that I maybe hearing as a peaked up top end, not the hf response droop.
Cheers George
Old 21st February 2013, 03:55 AM   #248
georgehifi's Avatar
Can anyone hear a 3 degree phase difference between 5khz to 20khz? And does it manifest itself as being a tad brighter?
Cheers George
Old 21st February 2013, 04:09 AM   #249
Hey George,
I wanted to give some 'pay back' for all the work you've done in the thread! Since you're not into Tina, feel free to request any sim.
Speaking of sim, all I wanted to show was the basic freq changes. I'm a bit leery of trying to connect even something that seems so basic as higher roll off = more highs
If this was basic filters maybe .... but this is a wacked out IV
Again, I don't understand enough about the common base configuration to know if the cap is required ...
What we do know is at least what the sim is telling us:
A lot more hi freq gets to the next stage with no cap ...
And there is some change to audio freq (I'll zoom in for you)
Seems minimal but you should know whats going on ...
Old 21st February 2013, 04:32 AM   #250
Here's pin 5:
And freq:
And close up 10Hz to 100kHz:
AD844 as a common base stage in the I/V converter Pedja Digital Source 44 14th September 2015 10:10 AM
WTB AD844 Opamps apassgear Swap Meet 6 31st January 2007 02:57 PM
Copyright 1999-2017 diyAudio
