Using the AD844 as an I/V - Page 16 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 21st January 2013, 10:01 PM   #151
georgehifi's Avatar
Send a message via MSN to georgehifi
I still think there maybe still more room for improvement.
I have done some more study of the AD844 in open loop mode with it's own buffer as the output, and the data sheet says the buffer as it is, is good only for driving up to 100pf of capacitive load, up to 1000pf with the feed forward network they suggest, which if I read right limits the current output drivability if used.
I measured the capacitance of what I'm driving interconnects and inputs and I think it's around 800pf.
I have two options one to use the feed forward network AD suggests which I believe comprimises the current output of the 844.
Or to use the buffer (attached), but this buffer is an unknown one and I wonder if it's output is able to drive the 800pf load it will see.
My next question is I have no idea how to sim circuits, can anyone sim this buffer I have (attached) which is availible on ebay for $10 to see if it can take up to 1000pf load on it's output without ringing or oscillating?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 21st January 2013, 10:46 PM   #152
jcx is online now jcx  United States
typically the C load limit is for closed loop operation - the C slows down the buffer, adds phase shift
can usally be stabilized with a series dcoupling R or ferrite bead - since the conrer frequency can be MHz there is little ausio consequence
Old 21st January 2013, 11:23 PM   #153
dirkwright's Avatar
You could use a BUF634 or an LME49600 instead. They'll drive just about anything.
Old 22nd January 2013, 12:14 AM   #154
georgehifi's Avatar
So are you saying jcx that in open loop operation which as you know is the way it's being used that the C load can be much higher than the 100pf stated without stability feedforward network?
Cheers George
Old 22nd January 2013, 02:23 AM   #155
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Yes that's what jcx is saying. The capacitive load limit is not due to the current capability of the buffer so much as the phase shift that's introduced. In open loop operation you do not care about phase shift very much, if at all because it has no consequence.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 22nd January 2013, 03:49 AM   #156
georgehifi's Avatar
So then because it's got short circuit protection, I can remove the series 47ohm I put in for safety sake, and let the output buffer drive direct from it's 15ohm source, even into a 800pf load without ringing or oscillation problems?
I know there's not much difference between 15ohm or 47ohm output impedance, but I always like the lower number if no problems arise.
Cheers George
Old 22nd January 2013, 04:06 AM   #157
abraxalito's Avatar
There won't be oscillation from the loop feedback no, but there's always the possibility of parasitics (much higher frequency oscillations) where emitter followers are concerned so if I were you, I'd isolate with an inductor (or ferrite bead) with appropriate damping resistor. This will maintain the low output impedance at audio and give some protection against HF parasitics. To be even more conservative, add a snubber (series RC) at the buffer output as is done with power amps.
Old 22nd January 2013, 05:08 AM   #158
georgehifi's Avatar
Like you explained way back post 15 http://www.diyaudio.com/forums/digit...ml#post3323415 but this time in series on the buffer output.
Cheers George
Old 22nd January 2013, 05:30 AM   #159
abraxalito's Avatar
Yes, or here's a more explicit example in the schematic I've put up for an ESS output filter - Build thread for Diyinhk ES9018 DAC on Ebay
In this example the opamp isn't open loop so more inductors are needed for stability. In your case probably just one or two is all that's required.
Old 23rd January 2013, 12:04 AM   #160
georgehifi's Avatar
Here are some screen shots from my 200mhz Tek scope, sorry no flash too much reflection. PCM1704 to AD844, TZ to ground via 2.7kohm with 500pf across it 844's output buffer straight to output rca's which were loaded with 50kohms
The funny one for me is the spiral oscillation on the 20khz sine wave anyone seen anything like this?,this noise dissappers at 12khz sine waves. Then after I put away all the gear I though maybe it was my smp bench light that was doing it. Next time I'll see again.
1khz square wave 2v
20khz sine wave
Noise on output .1mV per division 20mhz scope filter bandwidth
Noise on output .1mv per division 200mhz scope bandwidth
Cheers George
File Type: jpg Noise on output .1mV per division 20mhz BW.JPG (339.5 KB, 620 views)
File Type: jpg Noise on output .1mv per division 200mhz BW.JPG (346.3 KB, 598 views)
AD844 as a common base stage in the I/V converter Pedja Digital Source 44 14th September 2015 10:10 AM
WTB AD844 Opamps apassgear Swap Meet 6 31st January 2007 02:57 PM
Copyright 1999-2017 diyAudio
