Using the AD844 as an I/V - Page 14 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 19th January 2013, 10:20 PM   #131
MiiB is offline MiiB  Denmark
why not use a simple n-Jfet buffer...?? its simple and don't require any matching.
for use with higher current output DAC's it could be paralleled with a high quality resistor to lover the current injection. Not too sure if that would give a noise penalty though. but I will give a distortion benefit, as it sems like the AD844 suffers when the injected current is too high(ish)..
Or you could run mere 844's in parallel to deal with the higher currents. More in parallel would also do away with the need for an output buffer...
Old 20th January 2013, 05:32 AM   #132
georgehifi's Avatar
Send a message via MSN to georgehifi
I was today thinking of taking the output straight from pin 6 to the output rca's, as I think I have the same gain at this point, and it's supposed to have 80mA drive current at 15ohm output impedance, the only LP filtering I would have is the 1st order at TZ to ground of the 2.7k resistor and 560pf across it which gives -3db at 105khz. Do you guys think I'll be waisting my time with this setup? The PCM1704 is supposed to be glitch free, and maybe it doesn't have too much other noise?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 20th January 2013, 08:32 AM   #133
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Looks like you've fallen for BB's marketing in their datasheet George. The PCM1704 is only really 'glitch free' around the zero crossing, that's what they state in the details. Since its a co-linear DAC the zero crossing glitches are now occuring at -6dB sinewave amplitude. Besides that its R2R so high glitch across the board compared to segmented current source and resistor string types.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 21st January 2013, 12:16 AM   #134
georgehifi's Avatar
I've got something to tell you guys, but not just yet, I would like to know a little tech stuff that is beyond me at the moment.
You know by that data sheet the AD844 from it's output buffer is able to source up to 80mA from it's 15ohm output impedance, I take it that spec was given by AD with global feedback around the AD844.
Can someone with more knowledge than me tell me what happens to those two figures (do they change and to what) when the AD844 is used without the feedback loop as I am?
Cheers George
Old 21st January 2013, 12:21 AM   #135
abraxalito's Avatar
If you read the datasheet George you'll see that the 15ohms is an open loop figure. 80mA doesn't change with degree of feedback.
Old 21st January 2013, 01:52 AM   #136
georgehifi's Avatar
Ah yes that abraxalito, missed that.
Well this IC just keeps rewriting the books for me.
I did what most said probably wasn't ideal, I drove the audio output rca's directly from the AD844 buffer with a 47ohm resistor in series just in case, and looked on the scope and yes I did loose about 5% of gain, but I got rid of half of Silicon Valley as well, remember I had a single opamp for LP duty, a dual opamp for balance and single ended duty and a pair of fets for each phase as buffer outputs all after the AD844.
Noise you say? a big fat NO! no more than I had before, in fact a touch less because of the touch less gain, also I still able to hit 2.2v P/P at 0db 1khz from a test disc.
The noise that I watched for was on a 200mhz Teck scope using 400mhz leads, and to boot I cannot see/hear any either at full output.
The sound, yes the sound has taken another leap higher, the sound is just as dynamic rich and all that I said before, but it has become even more relaxing to listen to, yet can still put you through the back wall when needed with it's dynamics, this chip amazes me. I look at it now and think this is as far as I can go with it, then I thought, the guys here aren't too impressed with the output buffer circuit, I got to wondering is it possible to put a little feedback from pin 6 (output) back to TZ (pin 5) just to encase the buffer (sorta local feedback) to maybe make it better?
Cheers George LOVE IT, LOVE IT, LOVE IT!!!!!!!!!!!!!!!!
Old 21st January 2013, 01:57 AM   #137
abraxalito's Avatar
That would be positive feedback, also known as bootstrapping.
Old 21st January 2013, 02:00 AM   #138
georgehifi's Avatar
Is this a good thing, is it possible to do, will it make this buffer better for output driving duties?
Cheers George
Old 21st January 2013, 02:02 AM   #139
abraxalito's Avatar
It won't improve the buffer no, but it might make more drive available at the TZ pin. What was wrong with the buffer to begin with?
Old 21st January 2013, 02:07 AM   #140
Since this is getting technical, I thought I'd link back to one of the nascent threads from way back in 2006!:
DIYHiFi.org • View topic - "Op-amps unsuitable for audio DAC I/V" - myth?
Holy Heavy Hitters Batman!
Charles Hansen, John Curl, Walt Jung
And the gang!
Jocko, PMA, CarlosFM, Pedja, Elso
Pedja points out:
"Based on the measurements I've done using AD844 open loop I can confirm that there is a problem with its output stage since I've found it adding about 0.5% (at 2V RMS and 1kHz) to the overall open loop THD figure which is quite poor for the diamond buffer, even taking into account relatively low bias current. I hope you can, being the insider, shed more light on the reasons behind. ... "
Walt Jung responds:
"I'm not an insider at ADI, really never was, even when I worked there. Barrie Gilbert designed the AD844.
CFAs with husky outputs can do well, the 811 and 815 come to mind.
Yes, you can run the 844 as a DAC terminator, with roughly a 50R Zin. The current IO of the DAC becomes reflected at pin 5, so an R from 5 to GND recreates a voltage. R > 50R makes for gain. You still need a buffer to drive any useful loads, however."
And more from Walt on pin 5:
"Hello PMA. The buffer at pin 5 of the 844 will be a challenge. I suggest low-C high current xstrs like PN2907A and PN2222A, running the ouput on the warm side (several mA). I'd *not* use the parts spec'd on my website, unless you are really careful. The 2N6715/27 have appreciably higher C than do the above types. See: http://waltjung.org/PDFs/WTnT_Op_Amp_Audio_2.pdf for the general idea. ... "
The link still works!
Walt also mentions PS for CFB opamps:
"... one thing to look out for with CF amps is the dismal PSSR, due to the architecture. Thus, rock solid supplies are needed to get the most from them. If it sounds wunky, then investigate the PS first, I'd say ..."
PS Your enthusiasm is contagious and I think I have the pirate 844 IV pcb around here somewhere ... !
AD844 as a common base stage in the I/V converter Pedja Digital Source 44 14th September 2015 10:10 AM
WTB AD844 Opamps apassgear Swap Meet 6 31st January 2007 02:57 PM
Copyright 1999-2017 diyAudio
