Using the AD844 as an I/V
Old 10th October 2013, 05:11 PM   #661
smms73 is offline smms73  Portugal
smms73's Avatar
my guess . the tube is maybe a pentode , the linearity of the tube parasite capacitance permit the excellent linearity at 1Mhz.
ps: there will be no further developments of this simple scheme
SÚrgio Santos
Old 11th October 2013, 12:57 AM   #662
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Best cap is no cap. As good as circuits can be, they are ruined by the colouration of cap coupling.
Very simple though, is this it (Terry) Zenelectro?
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 11th October 2013, 11:04 AM   #663
TimA is offline TimA
Inspired by this thread I have replaced my common base AD844 output stage with Pedja's discrete version. With the TDA1541A I'm using it without a buffer as I prefer the improved transparency as I did with the AD844 with its output directly from pin 5. I have tried two versions, one using BC550/560 and the other with 2SA970/2SC2240, all selected for highest gain but not matched. Well worth the effort! The BC version is very dynamic and highly focussed, not kind to bad recordings but far ahead of the AD844 overall. The 2SC version is more laid back and is an easier listen, very refined, and is very open and delicate in the treble. Very happily living with this now.
Old 14th October 2013, 08:39 PM   #664
zenelectro is offline zenelectro  Australia
zenelectro's Avatar
Cheers George
Apologies - have been away.
There are a few ways to do it they all work, however the type of
components, voltages, currents, noise gains of CCS make the big difference.
Some of this shows up on sims some doesn't.
The same rules apply to the diamond I-V and this is why I dislike the 844,
you cant change the devices or currents. They are just a 'dumb' solution.
There is a further development which involves a distortion cancelling single
discrete semi that brings the simulations down to -140dB depending on DAC
but I've yet to try this in real life. It should work.
I'd build these up if there were enough interested but ATM there are some
other projects in front.
WRT caps versus no caps - the best systems I've ever heard had caps
in the signal path. Changing a circuit for the worse to negate a cap is, IMO,
folly. The only downside is you need to use good ones = can be expensive,
depends how you implement it.
Again, if you think a bit laterally there are much better ways to implement
the cap pre OP buffer which bring the cap signature down to very small
levels.
Old 17th October 2013, 08:38 PM   #665
optimationman is offline optimationman  United States
Thanks go out to Pedja/Georgehifi for this great idea. First I must say that I have only tried a single AD844 with internal buffer per channel in a sub-par layout. With oscillation, only three pin regulator +-12 volts, and the AD844 in a socket that had a dual IV opamp it sounds better that any other opamp system I have had. The greatest gain in my system was in the sound stage, which is projected across the front wall like never before. I have also noted that there is now greater low level detail, and better decay. I guess I discovered what the rest of my system sounds like. I am now in the process of removing the sockets and improving the decoupling. I would like some direction as to how to ground this chip. The board layout has a top ground plane under the chip and the ground track for the power supply running on the under side of the board. Pin 3 connects to both(thru a pin hole/via) and Pin 5 connect to the top board plane and to a small plane under the board(thru a pin hole/via). My thought was to connect pin 5 thru a resistor/cap to this top plane and connect pin 3 to both thru the pin hole(via). The output would go to the RCA jack from pin 1 and the top ground plane. The data sheet says the decouple caps should be taken to a point close to the load(or output connector). Should the decouple caps connect to the chip pins and the top ground plane(putting it close to the output connection), thus making the power supply ground contact thru pin 3 or should they be connected on the underside of the board to the ground trace(pin 3) and pins 4/7? Is there any difference? Maybe neither is optimal, but that is what I have to work with............For what it's worth, I have only one cap in the signal path, and would like to keep it that way.....
Old 17th October 2013, 09:07 PM   #666
dacen is offline dacen  Norway
Optimationman, can you tell us what type of D/A chips you are using?
Old 17th October 2013, 09:11 PM   #667
Dacen, I am using a PCM1704uj. And I am taking the output off of pin 6 and ground plane, not the previously stated pin 1, sorry
Old 17th October 2013, 09:28 PM   #668
georgehifi's Avatar
Hi optimationman, indeed it does sound far better than any opamp with feedback based way of doing I/V.
As for grounding the TZ point resistor, the way mine was done on two identical cdp's now was to use the same ground point that the old opamp i/v (opa627) used for it's pin 3 which is the analog ground plane.
As for the power +&- supply rails I was fortunate that the rails (+- 15v) for the the OPA627 were well regulated nice and smooth, and I just used them instead.
BTW what dac is your unit using, I I found that two 844's stacked per channel was a magintude better again even when using the low ouput PCM1704K dac's, and my friend has the same CDP and he says after I did it it's even better with 4 stacked, we have yet to do a direct A/B 2 vs 4 yet, maybe next week.
PS just noticed you are using PCM1704, definately do 2 stack, or even 4 as my friend love 4 and Sergio's sims back that up as well.
Cheers George
Old 17th October 2013, 09:45 PM   #669
HI Georgehifi, I have a factory board to work with so that is fixed. They used a dual opamp, but only one side(shorted out the other?)thus a difficult pin configuration to work with(dual vs single pin layout). I had to make some other changes because the original layout was differential PCM1704's(2 per channel) to only one per channel(long story). I was lucky enough to have really no offset on the two PCMs and less than 8mv offset with one AD844. I tried a quick but dirty mod just to see if it was really what I wanted, even the two up AD844s. However this dual arrangement upset the offset and I got 80mv on one and -22.4mv on the other. So I will go back to just one for now and try to figure a way to take care of the offset. Not to easy on this board as the PCM1704s are surrounded by silmic caps in close and no real access to them!
Old 19th October 2013, 07:06 AM   #670
georgehifi's Avatar
What a PCM1704 Evaluation Board from BB!!! nice never seen one post a pic of it.
Cheeers George
Using the AD844 as an I/VHide this!Advertise here!
AD844 as a common base stage in the I/V converter Pedja Digital Source 44 14th September 2015 10:10 AM
WTB AD844 Opamps apassgear Swap Meet 6 31st January 2007 02:57 PM
