Using the AD844 as an I/V
Old 19th January 2013, 06:59 AM   #121
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by georgehifi View Post
I wished they had old school multibit dacs though, then I would look/search for them s/h.
I find it particularly ironic that they don't, given Charles' staunch anti-feedback stance. He lets it under the radar when its hidden inside digital chips
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 19th January 2013, 07:14 AM   #122
jcx is offline jcx  United States
yes I've had an exchange with him where he denies local degeneration is negative feedback, and in the next line, same post, implicitly uses Blackman's Theorem to answer another question
hard to understand the position - is it bald faced lying to keep his marketing message intact?
Old 19th January 2013, 07:22 AM   #123
abraxalito's Avatar
No, I'd not say lying, just pretty common cognitive dissonance management. Never underestimate the power of denial.
Old 19th January 2013, 12:22 PM   #124
s3tup is offline s3tup
s3tup's Avatar
844 is already quite linear, yet isnt the best one on measurements. You could either wrap it with feedback (the linear circuit plus mild feedback approach) or make it beefier to accomodate larger current swings as they did in ayre.
Third option is to make it discrete and thus have a control on its current biasing and fanout.
4th option is to implement some distortion management circuitry...
Or just leave it alone and use proper dac with low current swing. Biasing the input current round zero is essential.
Dont forget that with no-nfb thing you have lots of passive filtering options.
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 19th January 2013, 12:27 PM   #125
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Here is a little from the now obsolete AD846 datsheet also can be used as current feedback opamp, seems it was the forerunner to the AD844, also had a TZ type pin 5. but was mainly used for bandwidth limiting compensation or as a low mA output point but they don't say what the output impedance is at that point either, looks to be similar architecture though.
Cheers George
I've seen used AD846 on ebay if they are that desirable.
So, what's left to do with the AD844 circuit? Is someone going to make a PCB for a group buy or something? I'm not sure if I'm interested myself, just curious.
Old 19th January 2013, 12:31 PM   #126
s3tup's Avatar
Why would you want a pcb for 8-legged dip device?
Especially with so many options of implementations available?
Old 19th January 2013, 01:41 PM   #127
dirkwright's Avatar
Then don't do it if you are not interested.
Old 19th January 2013, 09:23 PM   #128
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Thinking of trying this after, either from the AD844 TZ pin or from it's output buffer.
If I come from the TZ pin so as not to load it down because it has such a weak output will I have to remove R4 C2 & R6 on the attached buffer?
If I come off the AD844 output buffer I can leave R4, C2 & R6 in place?
Oops think we've gone over this a few weeks back, a little hung over this morning, big night.
Cheers George
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 19th January 2013, 09:44 PM   #129
AudioLapDance is offline AudioLapDance  Canada
Hey George,
You're aware of this thread?
DIYHiFi.org • View topic - I/V convertor output buffer
I have these boards as well and I'm getting high dc offset: +50 and +80mV.
How about you?
Using the trimming circuit will give you less offset but the FETs aren't well matched so the performance will suffer.
My upgrade path will be better matched 246/107 FETs then a more full Cascode.
Jeff
Old 19th January 2013, 09:59 PM   #130
georgehifi's Avatar
Thanks Jeff if it all works fine then yes there are matched pair/quads I can get off ebay, just need to know first if it all works out and if the total gain is enough and if the dc trim pot works as well, as I have something against coupling caps.
Cheers George
Using the AD844 as an I/VHide this!Advertise here!
AD844 as a common base stage in the I/V converter Pedja Digital Source 44 14th September 2015 10:10 AM
WTB AD844 Opamps apassgear Swap Meet 6 31st January 2007 02:57 PM
