DQ DAC 2, BIII SE, Tube-I-Zator, Arduino, Amanero Build - Page 7 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 3rd March 2013, 11:29 AM   #61
Working yet Dave?
Old 3rd March 2013, 07:49 PM   #62
DQ828 is offline DQ828  Australia
DQ828's Avatar
Originally Posted by Beau View Post
Working yet Dave?
No, not game to turn it on, Need to test everything first, I find it hard be believe I have all the wires in the right locations, it would be nice if I did work first time.
Old 3rd March 2013, 07:55 PM   #63
What was that saying, and also album from a rock band from down under, Airbourne? No Guts. No Glory.
Looks great! Nice work Dave!
Old 3rd March 2013, 11:29 PM   #64
DQ828's Avatar
No gut's No Smoke
Old 5th March 2013, 09:47 AM   #65
DQ828's Avatar
No smoke so far, but haven't got far.
I have been reminded why I shouldn't wire when it's late & I'm really tired. The A/C relay input board works, but haven't applied the full load yet. The 12v SMPS works, the tranny that I had wired up incorrectly still works probably helped by the fast blow 2A fuse I had in the A/C inlet. The Placid HD is working after a bit of confusion & the BIISE appears to be working, all lights on. I was worried when one of the LED didn't light up but it turned out the voltage was too low.
Old 6th March 2013, 09:05 AM   #66
DQ828's Avatar
One step closer, glowing tubes & still no smoke
Old 6th March 2013, 12:27 PM   #67
Crom is offline Crom  United Kingdom
Default Lovely job!
Really impressive build there. have you seen that Oliver has recommended alternative resistors. Mine is a dual mono build so I'm going to play with the values using cheaper resistors and then buy them to try out once I've got the right value sorted out.
http://www.diyaudio.com/forums/blogs...-resistor.html
Old 6th March 2013, 07:47 PM   #68
DQ828's Avatar
Thanks for the tip.
Old 9th March 2013, 10:42 AM   #69
DQ828's Avatar
Well there's good news & bad news, if you look at the photo's it wont be hard to pick some of the bad news
The good news is, it's playing music from the Amanero input & from the SPDIF input, solid lock on both. I cant comment on sound quality as I've cobbled together a couple of old SABA drivers & attached them to the Kingrex amp that normally doesn't get used anymore.
But there's plenty of bad news, obviously the bloody screens upside down I used a different screen but from the same supplier as my other DAC and assumed it would be the same, I don't know if it can be turned over via the software, I'm going to be really pissed if I have to physically turn it over. The other bad news is nothing on the screen actually appears to work, yes nothing. The volume numbers go up & down but it has no effect on the actual volume, the rotary encoder doesn't work, Input, Sample rate you name it, it doesn't work. I'd almost think the Arduino isn't actually talking to the BIII SE except I have music, thank goodness. Probably the only reason I can switch between sources is that on the BIII SE all you really need to do it is a couple of relays.
I'm starting to think I should have waited until somebody who was good at coding got a BII SE working before I went down this road as with my body of coding knowledge it could take the rest of my life to fix it
You know I really like listening to Aaron Copland, you guessed it that's what's playing. Oh, and it's playing via Foobar, which is another first.
You know all these problems but I've still got a big smile on my face, can't be too bad.
Old 17th March 2013, 09:13 AM   #70
DQ828's Avatar
I have been battling away trying to get the rotary encoder switch to work, you would think it was the simplest thing in the world to do but I have tried everything to no avail. I have changed the code to use the remote instead of the rotary encoder so I can change the BIIISE input parameters I would still like to get the switch working so I don't have to use up the limited remote keys, but I'm completely stumped with what is stopping the switch working.
I have also been trying to rotate the screen via the software but once again I have spent long hours playing with the screen controller .H file with no success. The software author says it's possible, but obviously not for me.
The screen is smaller than the one I used for the first DAC but it is definitely better, it's crisper & can be viewed from almost any angle. It's looking like I'm going to have to pull the thing apart & rotate the MEGA. I need to do it soon as my neck is killing me.
Tube-I-zator Professional PCB dvb projekt Group Buys 958 6th April 2017 12:28 PM
FS : Tube-I-Zator DAC IV pinnocchio Swap Meet 14 8th March 2013 01:35 PM
Use Arduino to control BIII bigpandahk Twisted Pear 4 9th August 2012 08:52 AM
Tube-I-zator SRPP DAC I/V-Stage circuit discussions dvb projekt Tubes / Valves 40 14th May 2012 03:23 PM
Arduino for pre-amp or DAC control Zero Cool Everything Else 2 6th August 2011 01:55 PM
Copyright 1999-2017 diyAudio
