| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#31 |
Well I think this is it, if you see anything obviously wrong I would love to hear from you.
![]() I was wondering about the grounding, at this stage the only things connected to the Earth point are the Earth AC Input & the Shield from the larger trannie, should anything else go back to the earth point? I haven't finished the wiring for Acko's isolator reclocker as I'm not sure how it's wired. I think everything else is done. The PDF is much better quality Last edited by DQ828; 24th January 2013 at 07:33 AM. |
#32 |
I want to dim the LED backlight to the screen I will be using, in the past I used the Arduino PWM output with a resistor in series to dim the backlight.
The manufacturer says I should ideally be using a transistor to do this & was kind enough to send me a mud map of how to go about it. In the drawing below I have shown what I think I should do to make this work but I am not sure I have got it right. The theory is that the LED backlight is supplied via the Drain & the Collector is supplied by the Arduino 3.3v output. The gate voltage is dropped from 5v to 2.1v by the voltage divider and the gate voltage is pulsed using the PWM function to turn the transistor on and off, the frequency of the PWM is changed to dim the LED. Can anyone confirm I have this right |
#33 |
Hi DQ828,
I've been following your build with interest and been trying to work out what components you are using to provide the 12v trigger out. I'd like to get my power amp to switch based on the DAC/pre I'm building. I can see that you've got a 12v feed from the transformer but what happens after that? Thanks for any help, Crom |
#34 | |
www.hifiduino.wordpress.com |
#35 | |
Those chips are analog switches for controlling the input selection (I2S/DSD or S/PDIF).
Twisted Pear Audio |
#36 |
Hi Brian,
From the BIIISE highlights on the website :- "High-precision, ultra-low-phase noise clock and integrated reclocking". There is some confusion in a number of threads here on DIYAUDIO leading to the incorrect assumption that the analoge switch chips are Flip Flops I appreciate you can connect and external clock but what does "integrated reclocking" mean exactly ? . |
#37 | |
RMAF11: Digital Jitter and Volume Controls, Martin Mallison, CTO, ESS Technology - YouTube Fast forward to 16:00.
#38 | |
Wish I had seen this video a while back. So the 9018 data sheet shows a DPLL that does not exist ! (and a set of DPLL registers that do exit) The "DPLL" is more like an advanced ASRC. I always wondered by MCLK was not a multiple of FS. This stuff is sinking in slowly. Martin Mallinson sounds like he comes from only a few tens of miles North of me. Pity he has moved away, I would gladly buy him a few beers over a chat. When you say "re-clocking the input clocks is a bad idea" I gather you mean in relation to 9018 MCLK, not just "cleaning up the edges" in relation to the transport clock. Thanks again for the information. Last edited by deanoUK; 29th January 2013 at 12:10 AM. Reason: Typo |
#39 | ||
is choosing a less facetious title...
You can also look at it in the way, that if there is nothing for it to do, because the input jitter is no more than that of the very low jitter clock and flip flop in series, it can only add error (even if it is silly small error), so the best result is actually that it doesnt know what to do and does nothing IMO. That is kind of the point of things like the fifo, to take responsibility for these functions and delete the crossing of clock domains altogether, making the transport and dac temporally one. at the very least it gets rid of the ESS warm up time for dropouts on hires material. there is no more data to show it is detrimental than beneficial. I've seen that video several times already, its quite interesting, he does waffle a bit, but in general I agree with most things he says and understand he has to pander to the audiophile masses somewhat with some of the language and make some stuff up for what parts even they dont really fully understand. However it is their stance that the ESS is essentially faultless in every way, in everything it does. that is not the case, it seems unusually sensitive to jitter on BCK, it seems unusually sensitive to ripple on ground in Async mode, the digital filter is not perfect and the MUX is a bit bunky and it is not source agnostic in my experience with both your ESS dacs and Ackos. I still prefer it over everything ive tried when used as a DAC only and will continue to use it for the foreseeable future, but I do believe that some of the integrated functions are now better served by more modern solutions to help it along. software or FPGA apodising digital filter, synchronously clocked buffered source/transport and external DSP are all better now ~4 years later. the ESS reclocking scheme is very good and was revolutionary at the time, but I do believe it has been superseded. you of course are rational to go with what your experience tells you just as I am. I do not believe either way is specifically wrong. Last edited by qusp; 29th January 2013 at 04:05 AM. |
#40 |
| Tube-I-zator Professional PCB | dvb-projekt | Group Buys | 816 | 12th May 2013 03:01 PM |
| FS : Tube-I-Zator DAC IV | pinnocchio | Swap Meet | 14 | 8th March 2013 01:35 PM |
| Use Arduino to control BIII | bigpandahk | Twisted Pear | 4 | 9th August 2012 08:52 AM |
| Tube-I-zator SRPP DAC I/V-Stage circuit discussions | dvb-projekt | Tubes / Valves | 40 | 14th May 2012 03:23 PM |
| Arduino for pre-amp or DAC control | Zero Cool | Everything Else | 2 | 6th August 2011 01:55 PM |
