| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#11 | |
Search Results flip H i F i D U I N O |
#12 |
At this stage I'm looking at leaving the 5v secondary unused & power the Mega & Relays with the XP Power ECE10US12 12V 10W PSU. It will simplify things & as it will not be connected to the audio side of things shouldn't be a problem. I am using a similar XP Power PSU in the other DAC (it was a leftover from another project) and all seems to be working fine.
#13 |
I thought I'd put the design out before I get too far. I have added the Acko Isolator Reclocker board as it looks like it will make my life easier in the long run.
I'd greatly appreciate any comments. Does anyone know the best way to power the Acko board & what voltage it needs. |
#14 |
Off the top of my head you'll need 3.3V supply to the acko board, unless he has provided a local LDO reg on the board, best to wait for the final BOM before worrying too much about that I think.
#15 | |
![]() The mega has 3.3 & 5V available, the BIII tranny & the other tranny have spare secondaries, so all I would need is a regulator I guess. |
#16 |
As the B3SE only has one SPDIF input and I would like to have 2 or 3 SPDIF inputs, I need someway of switching between the inputs.
Does anyone know if there is a small suitable device available to do this? As I will be controlling the DAC via an Arduino Mega I have the switching capability already on hand, if it is just as simple as installing a couple of relays I would greatly appreciate advice on what would be a suitable relay. I have read that SSR are not suitable for audio signals, but have no idea whether this is valid in all situations. |
#17 |
Two layout options, I'd appreciate any thoughts.
The relays down near the AC inlet will probaly go on a PCB & be mounted vertically so they wont take up as much room as on the drawing. Everything is drawn to scale. |
#18 |
is choosing a less facetious title...
input and output have LDOs on the isolator/reclocker looks like lt1763 3v3 LDO on the input and a tps type on the output
#19 | |
#20 |
| Tube-I-zator Professional PCB | dvb-projekt | Group Buys | 816 | 12th May 2013 03:01 PM |
| FS : Tube-I-Zator DAC IV | pinnocchio | Swap Meet | 14 | 8th March 2013 01:35 PM |
| Use Arduino to control BIII | bigpandahk | Twisted Pear | 4 | 9th August 2012 08:52 AM |
| Tube-I-zator SRPP DAC I/V-Stage circuit discussions | dvb-projekt | Tubes / Valves | 40 | 14th May 2012 03:23 PM |
| Arduino for pre-amp or DAC control | Zero Cool | Everything Else | 2 | 6th August 2011 01:55 PM |
