What happens to an audio signal from media player to dac - Page 7 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 11th January 2013, 10:44 AM   #61
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by mr_push_pull View Post
picoseconds you say? how about the $10k femtosecond MSB clock?
That's the one I was trying to recall, thanks. What's a factor of a k between friends in jitter anyway?
(nice sig BTW. but JMK is defunct as of now which makes for an interesting problem )
That's precisely why I quote it - for the irony factor You're the first to pick up on that - kudos.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 11th January 2013, 10:46 AM   #62
Julf is offline Julf  Europe
Originally Posted by abraxalito View Post
Haven't seen a trivial (i.e off-the-shelf) way to isolate UAC2 yet but I had heard that ADI was working on a solution. You know of a trivial solution?
Technology: Analog Devices
Off-the-shelf products: Acromag
Old 11th January 2013, 10:48 AM   #63
Send a message via Yahoo to mr_push_pull
Originally Posted by Julf View Post
The USB data cables are differential / balanced, so high common mode rejection should be easy to achieve.
I think this is exactly abraxalito's point as it's all dependent on cable construction and properties.
Ground/power is more problematic - but if you don't use the USB power, but have an independently powered DAC, galvanically isolating the connection is trivial.
this makes me wonder... how come galvanic isolation with high end DACs is not the norm?
speaking of which, did I see some noise measurements at CA?
we all love a good ol' stereotype until it's against us
Old 11th January 2013, 10:49 AM   #64
abraxalito's Avatar
Neither of those handles UAC2 - they're full speed [12Mbits] (as opposed to high speed [480Mbits]).
Old 11th January 2013, 10:54 AM   #65
abraxalito's Avatar
Its from my perspective part of the problem because of this currently fashionable word 'galvanic' - meaning its DC isolation. But DC noise isn't the problem, AC is - isolation at RF is called for which is a different matter from isolation at DC.
Regarding CM noise measurements - I also recall seeing some on CA, they originated from ExaDevices I think.
Old 11th January 2013, 10:59 AM   #66
Common mode rejection is more a function of the USB receiver circuitry, not the cable.
Could be - I have given up on CA except for the section on hi-res downloads.
Old 11th January 2013, 11:02 AM   #67
That's the beauty of a solution based on magnetics (transformer) - it provides both DC isolation and a low-pass filter.
Old 11th January 2013, 11:04 AM   #68
abraxalito's Avatar
True for common-mode signal (carried on the data pair) but not for CM noise which is carried on the ground too.
Old 11th January 2013, 01:44 PM   #69
n0vtz is offline n0vtz  United States
n0vtz's Avatar
I guess some of us might be sourpusses enough to ask for some kind of proof of the validity of your theory...
Ah, yes, so the people selling the stuff report differences. Right....
Bah-humbug; here we go
Actually, there can be differences in cables, but they are identifiable and measurable. I don't need to elaborate on impedence around here, and reactance is measurable. There are EMR and RFI consideration in some cases. Differences when they are not born in a overly imaginary mind are real.
Jim
Old 11th January 2013, 01:46 PM   #70
I don't think anyone is claiming there aren't differences in cables - I think the disagreement is about the audibility of those differences...
Multiple instances of media player to different audio outputs narituba PC Based 11 4th February 2017 09:34 AM
Digital Audio Media Player Choices Loren42 Digital Source 0 23rd May 2012 01:28 AM
Compact disc player sonic differences by various signal procesing devices before DAC tiefbassuebertr Digital Source 65 30th January 2012 05:18 PM
How can I convert SPDIF to EFM (RF) signal, to use a cd player as a DAC ? gaetan8888 Digital Line Level 10 8th February 2009 07:32 AM
Media player click with USB audio jmar Digital Source 1 5th February 2006 04:24 PM
Copyright ©1999-2017 diyAudio
