What happens to an audio signal from media player to dac
Old 11th January 2013, 10:55 AM   #51
Julf is offline Julf  Europe
Originally Posted by abraxalito View Post
I was speaking of my experience (IME expands to 'in my experience'), not my theory.
You have experienced some effects and possibly made some observations by making measurements. You are postulating an explanation for those effects. I would call that a theory.
Old 11th January 2013, 10:56 AM   #52
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
You're welcome to call it what you like In case it has escaped your notice, in science there's only ever falsification, never proof.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 11th January 2013, 11:08 AM   #53
mr_push_pull is offline mr_push_pull  Europe
Send a message via Yahoo to mr_push_pull
exactly what I wanted to say. I'd guess that common mode noise is not differentiated from jitter by listening alone, so maybe abraxalito has some measurements. also, aren't there any more effective solutions for CM noise than cables (low capacitance?)? and if a good cable is the only solution, is there any esoteric technology involved that justifies the prices?
we all love a good ol' stereotype until it's against us
Old 11th January 2013, 11:12 AM   #54
abraxalito's Avatar
Yes there are ferrites for CM noise on cables. Or CM chokes for balanced cables like USB - Steve Nugent (Empirical Audio) is even selling some CM chokes of his own design for a tidy sum Personally I would recommend spending as much on ferrites as on the cable - no more than single digit $.
Old 11th January 2013, 11:19 AM   #55
but then again, doesn't this mean that all those waxing lyrical about cable differences are describing noise flavors? aren't there readily-available USB cables with ferrites already fitted? I think I have one that came with some gadget at home.
Old 11th January 2013, 11:23 AM   #56
one more thing I meant to add, unrelated to the above. the accepted wisdom is that it's not the jitter amount alone that matters but its characteristics. random jitter is said to be less problematic than correlated jitter.
Old 11th January 2013, 11:29 AM   #57
abraxalito's Avatar
Intermodulation distortion caused between the audio and the HF noise yes. That would be my hypothesis. The solution that arises from this hypothesis is to provide better CM filtering on cables.
Here's a theory for you Julf as you're seemingly interested in those: The audio industry at large doesn't like the SQ differences to be down to something tangible like CM noise, they'd prefer to keep selling stuff that fixes up non-existent jitter problems. Like picosecond clocks for example. What do you reckon?
Yes but probably only to meet EMC regs, not to give low IMD.
Old 11th January 2013, 11:35 AM   #58
The USB data cables are differential / balanced, so high common mode rejection should be easy to achieve. Ground/power is more problematic - but if you don't use the USB power, but have an independently powered DAC, galvanically isolating the connection is trivial.
This of course doesn't apply to optical - no common mode issues there.
I agree that you probably have a point about the high end of the audio industry not being too keen on the answer being too easy, but I don't think that applies to the whole audio industry.
Old 11th January 2013, 11:40 AM   #59
worth trying as long as it's in the one figure range.
picoseconds you say? how about the $10k femtosecond MSB clock?
worth giving it a try though.
(nice sig BTW. but JMK is defunct as of now which makes for an interesting problem )
Old 11th January 2013, 11:41 AM   #60
abraxalito's Avatar
Haven't seen a trivial (i.e off-the-shelf) way to isolate UAC2 yet but I had heard that ADI was working on a solution. You know of a trivial solution?
Fair point - consider my post edited to qualify the word 'audio' with 'high end'.
What happens to an audio signal from media player to dacHide this!Advertise here!
Multiple instances of media player to different audio outputs narituba PC Based 11 4th February 2017 10:34 AM
Digital Audio Media Player Choices Loren42 Digital Source 0 23rd May 2012 02:28 AM
Compact disc player sonic differences by various signal procesing devices before DAC tiefbassuebertr Digital Source 65 30th January 2012 06:18 PM
How can I convert SPDIF to EFM (RF) signal, to use a cd player as a DAC ? gaetan8888 Digital Line Level 10 8th February 2009 08:32 AM
Media player click with USB audio jmar Digital Source 1 5th February 2006 05:24 PM
Copyright ©1999-2017 diyAudio
