| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
#81 |
It was while I was thinking about hacking the op amp power runs, that I decided I wouldn't be able to do it and this gnd plane improvement. Just too difficult for me. Maybe GLT can try ? So I did this because my experience with other DACs suggests the ground plane is more important for the noise floor.
I'm gonna start with thick film res on the underside and the TL1963 reg, and basically average ho hum components. Find out how bad it can be. Then do upgrades to see how they change things. I'm especially interested in the effect of fitting RN55 resistors over the top of new bit of copper ground vs the thick film on pads on the other side. But I'm STILL waiting for parts. Wait and see. Here's a pic of a ferrite I fitted to route the xo power in a loop around the trace for the xo signal.
#82 |
is choosing a less facetious title...
hmm it would have meant just cutting the trace on either side of each opamp, as it is now i'm afraid you are in a very similar position as before, the power is still routing under the output and effecting the impedance, but it should still be improved somewhat, hard to say how much though. gutsy move though, looks like the same copper strap I use...goertz?
forget thick film resistors, they have terrible VCR (Voltage Coefficient of resistance) and will add noise. oh I see you are making it as bad as you can? are you sure the TL is up for that much current with that..erm.. mounting? I suppose though given your low XO speed it should have less demand, I wouldnt expect it would be happy running with a 100MHz + XO though. what type ceramics are they? x7r? |
#83 |
Yep, that would be doable - six twisted pairs fed back to the regulators(s) - but a bit of a spaghetti nightmare for me. I'm not good at that. Another option is a catenary system with drop-downs at each op amp.
What I have done creates a ground layer over the power lines so the signal path can go over the ground, and hopefully that will be enough to mitigate the layout problem. I only use COG and X7R but to be honest I don't remember which these were. Probably X7R. |
#84 | |
I like your ferrite mod for the clock power. Very nice!
Regarding GND, I need to first figure out where are the return paths. 1/2 of the opmap and components are already on the "right" side... Quote:
www.hifiduino.wordpress.com |
#85 |
COG are way too expensive. :-)
#86 |
Are you gonna use thin film or through hole ? Through hole metal film might have an advantage. If you look at the smd pads for the 100R and 680R, it seems to me that I could cut the trace immediately after the through hole, disconnecting the pad. If I did this for both pads, then I could remove the surface screen surrounding them and solder the area so the pads are part of the ground plane on that side.
Cut the red lines, and then scrape and solder so the blue area is contiguous ground.
#87 |
I think that would work, but I don't think it is that important.
I read up about "ground return currents" from no other than Walt Jung... The return currents will flow under the signal lines (meaning if a bunch of electrons move one way in the signal lines, an equal amount of electrons would move in the opposite direction right under the signal lines. It is important to have an uninterrupted ground plane, otherwise the return current would have to around the break increasing impedance and susceptibility to external disturbances. In this board, here are 4 signal lines from the DAC to the opamps but they are interrupted by the power lines. The return current will flow right under the resistors if they could. So your mod is a good mod but if you move the GND bridges right under the resistors, then that would be optimal. In fact, you may not need a band, just some wires under the resistors as this is the shortest path for the return ground current to go through. On the top, if using a wire for the return current, it may be more advantageous to have the two resistors on top of each other. Elsewhere, there is uninterrupted ground under the signal lines, so the return currents flow right under the signal lines.
www.hifiduino.wordpress.com Last edited by glt; 17th January 2013 at 03:46 AM. |
#88 |
Thanks - that's a nice clear explanation. I understand ground returns - route of least resistance - and ideally, no resistance/impedance/inductance/capacitance right ? I wanted to put the copper right under the resistor pins but they're very close to the power lines and I'd risk shorting something, so I felt I had to angle them slightly. Because of that, I think that the copper strip is most likely going to help the power lines, not the signal returns. So, following your explanation, I'm going to do both ground changes because I think the second one is most likely to help the signal returns. I'd still like to see more vias between the ground planes on this board. I might drill a couple of 1mm holes and do it that way, but perhaps the two mods will be enough. How's your build coming along ? My parts are due to arrive later today, but I've got to teach this evening, so I'll be stuffing the board tomorrow. Thanks again for posting the explanation. ![]() Tom |
#89 |
I am learning as I go. Luckily there are books and articles from experts one can read.
The best practice basic approach is to have an uninterrupted ground plane "no matter what". Doesn't mean you cannot route on the ground plane, but Not break it under a signal line. The ESS board routes through the Gnd plane, so the current would just flow along the signal lines on the GND plane on both sides of the signal wire. The ESS DAC has a requirement that anywhere under the signal lines, there should be no interruption of the GND plane. This seems to be just "best practice" in the industry. There are more "tricks" that I've read from people in the know: Some people likes narrow power lines rather than "power planes" because it has more inductance and with the bypass capacitors they form a filter that further cleans up the power. Others prefer power planes because the added capacitance in the pf range provides additional bypass that is good for GHz operation. So in this case, narrow power lines seems the better solution... I am going slow. Not much time left after wife, kids, life and work. What you see in my blog is what I have... But my controller is all ready to go :-)
#90 |
I'm learning as I go too. There's a fantastic set of resources here :
I2S and digital signal path - in-line resistors? Do post some info here about the controller, or links to the relevant hifiduino stuff. I'd love to learn about that. Family first eh ? Good for you. ![]() Cheers, Tom |
| BUILD THREAD - A New Take on the Classic Pass Labs D1 with an ESS Dac | opc | Digital Line Level | 612 | 10th May 2013 01:29 AM |
| High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too) | merlin2069er | Digital Source | 354 | 7th April 2013 08:51 PM |
| Pass D1V3 DAC - build thread | spzzzzkt | Pass Labs | 224 | 8th December 2012 03:40 AM |
| Gamma-1 DAC build thread | mattmcl | Digital Line Level | 8 | 20th January 2012 11:27 PM |
