Build thread for Diyinhk ES9018 DAC on Ebay
Old 8th May 2013, 07:23 PM   #472
TheRob is offline TheRob  Poland
As of now there are several versions of this board so this thread is becoming a little confusing. Anyhow, I just received version 2013.07 of this board along with the DIYINHK XMOS 384kHz USB to I2S PCB. Everything looks great but there are markings and connections on the board which could use some documentation. For a newb like me this would really make things much less intimidating. Unfortunately, no documentation was included so I hope some good soul could perhaps make a list of these markings and explain their function.
I also have a few specific questions that hopefully someone will answer.
1. I would like to use the clocks from the USB to I2S pcb, so I don't plan on installing an oscillator on the DAC board. Do I need to connect anything else besides the I2S inputs between these two boards? Will the ESS chip recognize automatically that it needs to derive its timing from the I2S signal? Or maybe I have to connect something to between the X1 connection of the DAC and the USB board?
2. Can anyone else verify that going with separate left/right AVCC supplies is as good as DIYINHK claims?
3. If going with separate supplies for AVCC should these also have separate dedicated transformer windings or can they share the same one?
4. I plan on using this DAC with a single ended SRPP tube buffer, any hints as to where exactly I should steal the signal points on the board? Obviously I won't be populating the opamps and rest of the IV stage. Will the chip automatically operate in voltage mode if I connect these outputs to a 50k pot through a coupling cap? What if I want to use current mode, how do I enable it and what size of resistor do I use before the buffer?
5. What is the marking "Chip Address" on the DAC board used for?
Thanks in advance for the replies.
Old 9th May 2013, 10:54 AM   #473
mennezoe is offline mennezoe  Germany
Talking sabre 9018
Originally Posted by glt View Post
Judging by the name of the outputs (to be sure ask the manufacturer)
cs dac -pic1
v+ -12v.
mos pic2
gnd gnd------GND
spiclk pic3
mclk ---------Not used
dsp1
fs-----------LRCK
dsp2
sclk---------BCK
dsp3
data--------DATAsp digelaty
dsp4
dsps
hallo glt
I2S connection are right, sabre board is already running ,volume remotecontrol
with digelaty dsp.
sound high dynamic, friends are very impressed.
thank all
Old 9th May 2013, 08:46 PM   #474
glt is offline glt  United States
1 - You can use the master clock output from the XMOS to the clock input of the ES9018.
3 - Same transformer would be fine.
4 - Dac operates in voltage mode without an I/V even if you put a resistor across the output. For true current mode you need to fix the output voltage with an opamp.
5- Chip address is to set the address of the chip if you are using dual mono.
www.hifiduino.wordpress.com
Old 14th May 2013, 02:31 PM   #475
please can somebody tell me what is a tp level converter .
how is the shematik or can i by it.
i am building also the diyinhk sabre dac,and i need spdif input into the sabre dac, an wich pin is the input and gnd.
i have the last pcb diyinhk made 2013.05.
Old 14th May 2013, 03:40 PM   #476
TP level converter: The Buffalo III Digital-to-Analog Converter
It is to convert the consumer spdif levels (~1v) to 3.3v required by the DAC.
For the DAC, the default input for spdif is data-1
Old 30th May 2013, 01:45 PM   #477
farhun is offline farhun  United States
Has anyone experienced excessive heat on the ICs, particularly in the buffer? I have been strangely loosing LME49990's within just few weeks.
Old 30th May 2013, 02:42 PM   #478
Suprted1 is offline Suprted1  Norway
My ES9018 is about 30-40 degrees, and my opamps(ADA797) is maybe 40-50 degrees.
All other cirsuits is on modified boards like Musiland and so on.
Parts for trade,near Bergen : ES9023P chips, Musiland 01 USD, DAC board with CS8416 and CS4397, Audax HT300G0 12" bass, DENON DVD-3910, Pioneer CD-player. Interested in okey PSU or audio stuff :-)
Old 30th May 2013, 06:52 PM   #479
I meant IV opamps, 6 LME49990s. I've build two boards, both have the same heat problem. What may cause that?
Worst are the last two opamps, they reach ~90-100 degrees Celcius. I have changed power supplies, built multi-stage regulated supply with independent Salas LV regulators for analog, digital, and IV stages, noisewise they are very clean and voltages are not exceeding the standards; 3.3V for digital, 3.45V for analog, and 12.2V for IV. I'm seriously puzzled.
Old 30th May 2013, 06:58 PM   #480
Jackal29a is offline Jackal29a  Spain
Maybe they are oscillating, proper decoupling as recommended in their data sheet is very important for proper operation.
Build thread for Diyinhk ES9018 DAC on EbayHide this!Advertise here!
Build Thread - A New Take on the Classic Pass Labs D1 with an ESS Dac opc Digital Line Level 719 26th May 2018 07:24 PM
High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too) merlin2069er Digital Source 354 7th April 2013 08:51 PM
Pass D1V3 DAC - build thread spzzzzkt Pass Labs 224 8th December 2012 03:40 AM
Gamma-1 DAC build thread mattmcl Digital Line Level 8 20th January 2012 11:27 PM
