Build thread for Diyinhk ES9018 DAC on Ebay - Page 47 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 25th April 2013, 01:17 AM   #461
glt is offline glt  United States
Judging by the name of the outputs (to be sure ask the manufacturer)
cs dac -pic1
v+ -12v.
mos pic2
gnd gnd------GND
spiclk pic3
mclk ---------Not used
dsp1
fs-----------LRCK
dsp2
sclk---------BCK
dsp3
data--------DATA
dsp4
dsps
www.hifiduino.wordpress.com
Old 25th April 2013, 01:20 AM   #462
Originally Posted by mennezoe View Post
ok glt
also another question.i read there are opportunities to connect,raw differential output, so may be some one can tell me wich points are the rights for left an right and gnd left and right.
so hope someone can help me
$99 ES9018 DIY DAC BOARD | H i F i D U I N O
Old 25th April 2013, 07:27 AM   #463
qusp is offline qusp  Australia
qusp's Avatar
just make sure its not driving too much resistance, i'm not sure about how this would effect the dac re output voltage compliance. glt you drove poweramps direct for a while, did you have any problems? I did direct and also passive IV as well as transformers, but all were no higher than 1kΩ
Old 25th April 2013, 05:06 PM   #464
Still driving poweramps directly (UCD180HGs). Haven't had a chance to try a proper I/V yet.
Old 26th April 2013, 04:57 PM   #465
Unhappy output
ok and hello glt and all of you
thank you for your answer,i will later test the I2S connection, but it is not al finished, the builder of the dsp is not available at present,google digelaty some nice pcb`s
i undersand more and more ,but not enough.
now i no what i need at last.
the row differential outputs needing a puffer,right?
so i dont use, only i will build a tube buffer.
i need a buffert differential output , to go to a resistor volume control ,
and than in to the power amp.
i have the pcb number 5 .
on hifi duino ( i think your block) is shown the point , were i can take differential output . one point from the opa , this point connect a 470 ohm resistor .
the pcb 5 layout is different to number 2 ,so i only have to look wich points are going from the 4 OPA`s to the resistor with 470 ohm,right?
and i dident need the two output OPA`s right?
ore, how can i connect the singel ended output with a resistor volume control and then in the power amp
regards mennezoe
Old 28th April 2013, 10:37 PM   #466
http://www.esstech.com/PDF/Applicati...PCB_Layout.pdf
Old 28th April 2013, 10:47 PM   #467
hello
is this the differenzial output ,link : ( http://www.esstech.com/PDF/Applicati...PCB_Layout.pdf) i can take for normal chinch (rca ) jack`s ,to a pre amp,
and i need only the parts after the OPA`s for the (low pass),
thank you for answer
that will come
Old 29th April 2013, 01:56 AM   #468
qusp's Avatar
no, you need the last 2 summing opamps unless you have a balanced amplifier, they take the balanced dac output and convert to single ended (RCA) as well as final filtering
Old 29th April 2013, 02:01 AM   #469
qusp's Avatar
you could connect the single ended output to a pot directly, but the resistance value of the pot will affect the output impedance.
why do you need a pot? just use the ESS inbuilt volume control with arduino, its VERY good. then you can connect the SE output to your poweramp directly
Old 29th April 2013, 07:09 AM   #470
Default output
hello
my dsp has a volume control already but sometimes my kids playing with the remote control,and they adjyst it. than the speaker became full power,so i need a passiv volume control like albs ,or so. to save it.
iam very beginner of dac building,i build tube amps and class d amps and pre amps, the shematiks are more easyer for me.
so my question ,a cd player a dvd player has a analog output ,between i can ged a passiv volume(like albs control ore a preamp).
and is the se output the same like cd ore dvd player,
BUILD THREAD - A New Take on the Classic Pass Labs D1 with an ESS Dac opc Digital Line Level 673 25th January 2017 08:52 PM
High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too) merlin2069er Digital Source 354 7th April 2013 09:51 PM
Pass D1V3 DAC - build thread spzzzzkt Pass Labs 224 8th December 2012 04:40 AM
Gamma-1 DAC build thread mattmcl Digital Line Level 8 21st January 2012 12:27 AM
Copyright 1999-2017 diyAudio
