Build thread for Diyinhk ES9018 DAC on Ebay - Page 46 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 17th April 2013, 05:11 AM   #451
qusp is offline qusp  Australia
qusp's Avatar
yes, glt is right (and getting lazy so didnt answer hehe) without a controller the dac starts up in defaults on everything and is stuck on the defaults for everything. the defaults look for spdif on spdif input 1 and input 1 only in default and that same line/pin is needed for i2s.
basically to do what you want to do without a controller will require a hardware hack and it will not be optimal, very unlikely to be cheaper or easier either.
the error caused by a relay or switch for spdif, depends on the relay and layout, you would be better off using one of the ti or potato semi MUX/buffers or an RF relay than a standard signal relay, but then you have termination stuff to take care of; not for beginners, many manufacturers dont get it right. the autodetect is good, but not perfect
Old 17th April 2013, 06:50 AM   #452
vuki is offline vuki  Croatia
vuki's Avatar
Originally Posted by redrabbit View Post
....I'll check your site about a controller.......
What is the degree of difficulty when adding an external controller "?
Glt's hifiduino is the best option. It's very easy to implement and you also get display, volume control, filter control etc. Great stuff!
Old 21st April 2013, 08:25 AM   #453
Hi all, do any of you know if i can connect a zapfilter 2 on this dac?
Old 22nd April 2013, 09:50 PM   #454
redrabbit's Avatar
I think I'll do just that !!
Got the Arduino Uno R3, a proto shield kit, and a 16x4 display.
Waiting for the Amanero USB board and some other module parts and molex connectors, etc...
I won't ask all the questions I have still.....most all the info is out there.
Except one....because of my inexperience in writing code....
Is Hifiduino code for the Sabre32 (es9018)....the same for this board, as it is for the Buffalo and others ?
.....Are there any changes to be made after uploading the code, before sending it on to the UNO ? (specifically, the spdif/I2S source switching) ??
BTW.....it would be very helpful if someone would post a "block diagram" for a completed setup. I'll mock one up when I think I'm close to connecting all the parts together.......and post it here, for approval.
Old 23rd April 2013, 04:43 AM   #455
redrabbit's Avatar
(edit... 20x4 display)
Old 23rd April 2013, 05:07 AM   #456
glt is offline glt  United States
Several people have used it with the board with no changes.
www.hifiduino.wordpress.com
Old 23rd April 2013, 12:45 PM   #457
qusp's Avatar
glt, whats been your experience with OLED? I still find the colours a bit garish and was thinking vfd, but I do like the idea of colour
Old 23rd April 2013, 07:27 PM   #458
Default connect I2S right
hello
i am building also the sabre 9018 from diyinhk.
i have befor the dac, a dsp with I2S connection,but there are a lot of connection,with other desciption,
so my question is can somebody help me to tell me the right connect,from my digelaty dsp I2S to the diyinhk dac I2S ,it can only
four connections be right.
i am beginner in dac and i think this is not the lightest dac .
i took a link on this post and so you will see.
Click the image to open in full size.https://docs.google.com/viewer?attid...umber=3&w=2000
the I2S is J5
i hope someone can help me
regards mennezoe
Old 24th April 2013, 05:03 AM   #459
Link is password protected...
Old 24th April 2013, 07:38 PM   #460
Unhappy connect I2s right
ok glt
i am to stupid to copy the shematic,i can also write it.
cs dac -pic1
v+ -12v.
mos pic2
gnd gnd
spiclk pic3
mclk
dsp1
fs
dsp2
sclk
dsp3
data
dsp4
dsps
this isthe I2S connection of my dsp.
also another question.i read there are opportunities to connect,raw differential output, so may be some one can tell me wich points are the rights for left an right and gnd left and right.
so hope someone can help me
BUILD THREAD - A New Take on the Classic Pass Labs D1 with an ESS Dac opc Digital Line Level 676 15th March 2017 09:38 PM
High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too) merlin2069er Digital Source 354 7th April 2013 08:51 PM
Pass D1V3 DAC - build thread spzzzzkt Pass Labs 224 8th December 2012 03:40 AM
Gamma-1 DAC build thread mattmcl Digital Line Level 8 20th January 2012 11:27 PM
Copyright 1999-2017 diyAudio
