Build thread for Diyinhk ES9018 DAC on Ebay
Old 8th April 2013, 12:57 PM   #431
Dxvideo is offline Dxvideo  Turkey
Dxvideo's Avatar
Send a message via Yahoo to Dxvideo
Originally Posted by vuki View Post
You can use transformer, but I would prefer at least 600Ohm:600Ohm model (eg. LL1545a). I have Cinemag Cmli-15 and it sounds excellent. Tried full active variant of output stage, but settled with active I-V (ADA4898) and transformer output. Voltage out with transformer also sounds nice.
I see..
But in voltage mode (without any active buffer) do you think ES9018 can drive a 600R primary?
Best regards,
Ozgur
Old 8th April 2013, 01:10 PM   #432
Jackal29a is offline Jackal29a  Spain
Originally Posted by Flac View Post
would be very helpfull to provide with a link to that thread.
I can't find it searching for combo384.
Btw, I've used version 1.09 and I think it's using firmware 1073c. Don't know how to see which version of the firmware is currently running, any tips here ?
Check here:
http://www.diyaudio.com/forums/vendo...ml#post3351431
If you have an early Combo board I suggest you update both CPU and CPLD using V. 1.10a of update tools.
Firmware v 1073c is supposed to be in beta state, 1072 can give problems with some DACs and I2C commands, 1069 is stable.
Old 8th April 2013, 03:05 PM   #433
Flac is offline Flac  Netherlands
Originally Posted by Jackal29a View Post
Check here:
ímuchas gracias
Old 8th April 2013, 03:40 PM   #434
vuki is offline vuki  Croatia
vuki's Avatar
Originally Posted by Dxvideo View Post
I see..
Yes.
Old 8th April 2013, 03:49 PM   #435
syklab is offline syklab  United States
Check here:
Is the firmware 1069 deployed via the "combo384_drivers_win7_win8_1056.zip" ? Since this is the pnly version available for download from the amanero site.
Old 9th April 2013, 02:27 AM   #436
glt is offline glt  United States
OEMTool (in the other directory)
www.hifiduino.wordpress.com
Old 9th April 2013, 06:12 AM   #437
luxury54 is offline luxury54  Romania
@glt , did you have any chance of comparison (sound wise) between the amanero and the CM6631 (that I saw you just purchased) using the same DAC and audio chain ?
== There are no limitations to the self except those you believe in ==
Old 9th April 2013, 07:14 AM   #438
As Glt says you need to use OEMTool NOT the drivers. Follow the link in my previous post, everything you need to know to flash the firmware is there.
Old 9th April 2013, 07:29 AM   #439
Dxvideo's Avatar
Yes.
Thx Vuki.. I'll try that..
Best regards,
Ozgur
Old 9th April 2013, 08:37 AM   #440
Got it.
Build thread for Diyinhk ES9018 DAC on EbayHide this!Advertise here!
Build Thread - A New Take on the Classic Pass Labs D1 with an ESS Dac opc Digital Line Level 719 26th May 2018 07:24 PM
High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too) merlin2069er Digital Source 354 7th April 2013 08:51 PM
Pass D1V3 DAC - build thread spzzzzkt Pass Labs 224 8th December 2012 03:40 AM
Gamma-1 DAC build thread mattmcl Digital Line Level 8 20th January 2012 11:27 PM
