Build thread for Diyinhk ES9018 DAC on Ebay
Old 12th March 2013, 01:37 AM   #361
KlipschKid is offline KlipschKid
Cool ! I'll be interested to hear how it compares. You have a different version of the board so if you can, please post a photo of the routing on the other side. Thanks.
Old 12th March 2013, 10:43 AM   #362
themystical is offline themystical  United Kingdom
Originally Posted by guglielmope View Post
Hello,
the board works!!
My proto ES9018 player.
I'm waiting for the new relese.
I use external SEN I/V
In the next days I'll compare with Buffalo II
Ciao
Guglielmo
Looking forward to your comparision. What are your first impressions?
Thinking of getting a couple of these for a dual mono application. Has the latest pcb incorporated any of your suggestions? What pcb design features have been added to the latest version available?
Old 13th March 2013, 11:16 AM   #363
diyinhk is offline diyinhk
Wow! seperate the ES9018 AVCC_R/L power supply provide a much more 3D sound stage.
The location of every instrumentals is much much more clear
It's like listening the different of a vertical piano and a grand piano,
This is really a breakthrough even after many layout improvement since the first version
I finally know why many diyer want dual mono config or at less seperate AVCC_R/L power supply.
this version will be available after the last few pieces ex-version is out
Old 13th March 2013, 09:27 PM   #364
guglielmope is offline guglielmope  Italy
Did you add other modifications?
Ciao
Guglielmo
Old 15th March 2013, 03:16 AM   #365
fredlock is offline fredlock  United States
How much is the cost of the new version?
Old 16th March 2013, 10:53 PM   #366
rade95 is offline rade95  United States
diyinhk I just ordered a board and you sent me the old version. Why? I am quite annoyed at this point.
UGS pre, stock F5, PassLabs X2.5, Aleph P
Old 17th March 2013, 02:12 AM   #367
this version has some component value missed print, the whole batch is went to the rubbish bin It should available soon
Old 17th March 2013, 02:37 AM   #368
Suprted1 is offline Suprted1  Norway
Is there any special reasons why analog / digital ground has not been separated ?
Old 17th March 2013, 12:06 PM   #369
qusp is offline qusp  Australia
qusp's Avatar
it shouldnt be, that would be a bad idea to separate the grounds like that, you would just be asking for ground loop currents inside the chip.... in general its a bad idea, if you want to shield delicate grounds from strong circulating currents, put a slot in the ground, but maintain a single ground.
funny that slowly some of the failings I suggested before the production boards were even made are being 'discovered' one by one as time goes on. I didnt discover them either, but I was criticized for being picky for suggesting them and fought every step of the way.
the dac chip has separate supplies, references, everything for the L/R channels; use them.
Old 17th March 2013, 02:44 PM   #370
IMHO I would believe that a complete separation of analog/digital ground with be a very positive mod. Due to the high frequencies working on the digital busses. And a separation from USB ground from computer. Which in total should reduce noise ??
Or is there better ways around this ?
Or isnt it an issue ? Then I would like a short explanation if anyone got it.
Thanks for reply :-)
Build thread for Diyinhk ES9018 DAC on EbayHide this!Advertise here!
Build Thread - A New Take on the Classic Pass Labs D1 with an ESS Dac opc Digital Line Level 719 26th May 2018 07:24 PM
High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too) merlin2069er Digital Source 354 7th April 2013 08:51 PM
Pass D1V3 DAC - build thread spzzzzkt Pass Labs 224 8th December 2012 03:40 AM
Gamma-1 DAC build thread mattmcl Digital Line Level 8 20th January 2012 11:27 PM
