Go Back   Home > Forums > Source & Line > Digital Line Level
Old 25th January 2013, 08:08 AM   #201
Yeah, cool party-wear too ;-)
Here's the happy couple, ready to say their vows :
I drilled one extra hole in the ES9018 board near the op amp power input. It's the only corner with a free space for a hole, that still gives reasonable access to connection points. Total height of the two together is 45mm.
Honeymoon shot - ewweeyy.
Old 25th January 2013, 08:16 AM   #202
syklab is offline syklab  Hong Kong
Hi Tom,
What are those 2 rows of dip connectors in the middle used for?
Interest are building up, I will try to build this dac after CNY.
Cheers
Old 25th January 2013, 08:27 AM   #203
Originally Posted by syklab View Post
Hi Tom,
Cheers
They are op amp sockets for the I/V. I cut the bridges so I could keep access to my ground strap, should I need to modify it. I put an op amp into the dip sockets while soldering to make sure they are correctly aligned.
I have fitted the buffer LME49990 op amps w/o sockets as I'm certain they are keepers. But I can still de-solder them from the adapter pcb if something better does come along.
Old 25th January 2013, 09:58 AM   #204
qusp is offline qusp  Australia
is choosing a less facetious title...
qusp's Avatar
Looks nice, does it comes in more than 5X magnifying power or is 5X enough ?
try to magnify something in photoshop to 500% and answer that for yourself, if you need more than 5x magnification, you should think about finding another hobby. also higher than that if you move your head more than a little bit, it becomes jerky.
Old 25th January 2013, 02:00 PM   #205
Default Magnification
When I turned 50+ I started buying reading glasses in 3 packs [eyes fine otherwise] -- when I'm down in the basement playing with SMD stuff I wear 2 pair, it helps if they are clean I'm NOT suggesting it's the best solution. That's ~2+ 2+ for me. I also have a large illuminated magnifier I found someone had discarded, it is not installed yet, probably nowhere near enough on it's own. Do my glasses help me find a tiny $pec of SOT-23 Micrel regulator I drop? NOPE!
Old 26th January 2013, 07:10 AM   #206
glt is offline glt  United States
Default 1.2V Regulator
I switched the ADP151 regulator for a LT1963A regulator. The LT1963A adjustable has a noise level of 14 uV RMS compared to 9 uV RMS in the ADP but vastly more capable in current capability. Building the $99 ES9018 DAC Board H i F i D U I N O
www.hifiduino.wordpress.com
Old 26th January 2013, 07:36 AM   #207
qusp's Avatar
why arent you using the TPS47xx? the transient response of the 1963A isnt so hot, it relies very heavily (as many LDOs) on the capacitors. I quite like the 1963A i've used it regularly for the same reasons you describe, but the TPS represents a changing of the guard for me, especially since it has a negative counterpart.
Old 26th January 2013, 07:40 AM   #208
I wanted to use that, but the minimum output voltage is 1.4V. Don't want to overclock the chip :-). I will use it for the input 3.3v supply
Old 26th January 2013, 09:12 AM   #209
Great job, as always GLT !
What do you guys think of the ADP7104 ?
BTW, diyinhk is selling two more DIY DAC boards, and I've always wanted to try the AKM AK4399.
Old 26th January 2013, 10:30 AM   #210
Originally Posted by diyinhk View Post
Delta-sigma DAC VS Test
reference condition:
Same I2S input,
Same headphone AMP, same headphone, same ear
Same power regulator
Same computer USB input
ES9018 VS PCM1794A VS AK4399
follow each offical datasheet demo IV LPF circuit
blind test,
only ear will told the best
p.s. the latest version ES9018 PCB with the latest es9018 chip seems have no unlock problem at default power on setting with asyn 100M clock with cm6631a, need to confirm with longer test time.
Very interesting DACs, though DSD1794a instead of PCM would have been even more interesting IMO.
Could you please post a better pic of the AK4399? It is very difficult to read the connectors' labels in that one. The one on your ebay store is fine for the other side.
Could the +/-12V be upped to +/-15?
BUILD THREAD - A New Take on the Classic Pass Labs D1 with an ESS Dac opc Digital Line Level 613 Today 12:21 AM
High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too) merlin2069er Digital Source 354 7th April 2013 08:51 PM
Pass D1V3 DAC - build thread spzzzzkt Pass Labs 224 8th December 2012 03:40 AM
Gamma-1 DAC build thread mattmcl Digital Line Level 8 20th January 2012 11:27 PM
Copyright ©1999-2013 diyAudio
