Build thread for Diyinhk ES9018 DAC on Ebay
Old 24th January 2013, 02:50 AM   #171
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Originally Posted by KlipschKid View Post
...thank you for your blog. You should be mightily pleased with that - a quality blog.
+1 - especially appreciate all the eye-candy - digital audio pr0n
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 24th January 2013, 04:39 AM   #172
glt is offline glt  United States
Originally Posted by qusp View Post
honestly, just go with synchronous clocking and be done with it.
they have a 100MHz Epson SAW at digikey make sure to get the CMOS version. they apparently do a 98.304MHz sop you could at least have synchronous 48x
3ps RMS and a quite large 25ps peak to peak jitter.
The journey IS the destination...
For 3.3V clocks, only the 75MHz and the 106 MHz are available.
The only reason I bring these up is because over at the other thread, side by side listening comparison, listeners preferred the BII with the saw clock to the one with the cchd clock.
www.hifiduino.wordpress.com
Old 24th January 2013, 04:54 AM   #173
BTW, your Arduino pages make that look really easy - is it ? What do people usually struggle with ?
Cheers
I think the hardest part is familiarizing with the Arduino environment (which is actually pretty easy). I don't get many questions. Most implementations "just show up" in some forum or blog :-)
Old 24th January 2013, 05:00 AM   #174
Did you decide on op amps yet ? I've settled on LME49990 for the buffers but still trying op amps for the I/V.
Cheers
I was thinking of first using the DAC in voltage mode single ended by flipping the phase of the second set of DACs and summing it with the first set (thus having 16 DACs per channel in SE mode). And then also try the passive filter from abraxalito.
Have a set of OPA627 somewhere in the closet that I will try.
Old 24th January 2013, 06:20 AM   #175
qusp is offline qusp  Australia
qusp's Avatar
the above would defeat ALL of the careful routing, all of the CMRR. I would expect less than 90dB THD+N
Old 24th January 2013, 06:26 AM   #176
qusp's Avatar
umm I have a result for CMOS 3v3 SAW 100MHz right in front of me, the one I linked you to. here they have 878 of them at 3.72 each. maybe yopu mean a different model?
sorry I cant say I place much stead in this audible comparison, a controlled test I suppose? yet another magical unknown specification that science forgot; yet brings audible levels of improvement when it comes to music listeners. Dark Jitter....people have been saying they prefer clocks that are clearly borderline browning out their dacs as well.
but like I said go for your life its cheap.
I can see it (the 100MHz or 98.304MHz) as a viable alternative if you dont want to blow the money on a crystek or better, I really can, they seem reasonable for the money. We are talking about a clock here, if it had other harmonics, they would be part of the jtest, so unless people prefer more error like they can prefer distortion, then it hurts my head to think of why you could prefer something worse.....and it is worse.
it seems to measure about the same, or a bit worse than the generic place-holder clock in the fifo kit
Old 24th January 2013, 06:49 AM   #177
abraxalito's Avatar
They're making the same noises over on the Oppo 105 thread too - SAW subjectively trumps the more expensive Crystek, despite measuring worse. I'm curious to understand why
Old 24th January 2013, 06:50 AM   #178
qusp's Avatar
yes, the same few (2?) people are making the same noises, one of whom uses it in his clock module upgrade....
Old 24th January 2013, 06:52 AM   #179
abraxalito's Avatar
Long-range scanners are reporting a rapid build-up of cynical expectation bias captain...
Old 24th January 2013, 07:03 AM   #180
qusp's Avatar
that would be fair, especially since the spruking of said commercial modules is a kind of sport in that thread.
but really, where is this unknown variable that makes the timey wimey machine more timey wimey-er?
Build thread for Diyinhk ES9018 DAC on EbayHide this!Advertise here!
Build Thread - A New Take on the Classic Pass Labs D1 with an ESS Dac opc Digital Line Level 719 26th May 2018 07:24 PM
High Performance WM8741 Upsampling DAC New Version build thread (show 'n tell too) merlin2069er Digital Source 354 7th April 2013 08:51 PM
Pass D1V3 DAC - build thread spzzzzkt Pass Labs 224 8th December 2012 03:40 AM
Gamma-1 DAC build thread mattmcl Digital Line Level 8 20th January 2012 11:27 PM
