| Digital Line Level DACs, Digital Crossovers, Equalizers, etc. |
I am curious - what exactly is a typical spdif receiver built around ? Is it a microcontroller ? Is it hardwired for all the logic and processing that goes on inside or is it software driven ?
Things like detecting the preamble and channel status bits and decoding the frames into the actual sample, and ofcourse the whole pll/clock recovery business. And now receivers like WM880x incorporate a so called "buffer" to eliminate jitter down to 100hz. So on what platform are such things implemented ? Is it a highly customized hardware application (hardware building blocks like gates and flip flops tied together) or is it some sort of a processor handling everything by software ? I know of "aftermarket" implementations using FPGA and XMOS and such but I asking about that $2-$5 chip you can buy from TI or CS or WM. |
#2 |
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
I'd guess its a purely digital hardware state machine plus a PLL which is digital in the case of the WM8805 and analog in the others. So 'yes' to your question about is it flip flops and gates - doing it in software would require more power and more silicon real-estate I reckon.
When a measure becomes a target, it ceases to be a good measure. C.A.E. Goodhart |
#3 | |
I understand in 1980 processing power especially in miniature form was not available but today its a different story. |
#4 |
Its a job for a state machine compiler- you could do this with a CPLD I guess and there are high level languages for programming them, like Abel. That's a hardware description language - http://140.113.144.123/Creative/abel_ref.pdf
#5 |
noticed the RD30 has its own software spdif receiver, says its even handles 187.4khz. Probably easier for the designer to start anew than figure out the silly WM8804.
Times they are a changing. |
| PCM 1794 Architecture/Concept?? | bear | Digital Source | 19 | 16th June 2011 07:01 PM |
| The Viola open architecture of Tom Colangelo | rintek | Solid State | 2 | 1st July 2004 08:50 PM |
| DIR1703 vs. CS8416 SPDIF receivers | machinow | Digital Source | 3 | 5th June 2003 07:38 AM |
