AD1865 schematic
AD1865 schematic
Old 19th April 2013, 10:06 PM   #51
skouliki is offline skouliki  Greece
skouliki's Avatar
I made a few changes: Made the tracks a bit thicker (0.64mm) fixed a connection to pin 14 of AD1865 that didnt exist, moved the regulator closer to analog +5v supply of the IC and also made a board without Mic5207 regs for experimentation purposes. I will probably etch and build the boards on monday hoping that alligning the toner transfers wont be a huge pain(also hoping that the boards actually work! ).
Old 20th April 2013, 08:12 AM   #52
JLOP is offline JLOP  France
Nice to see its going well Skouliki ! I let you explore the thing
Old 6th May 2013, 08:33 AM   #53
bambadoo is offline bambadoo  Norway
Any progress here?
Old 6th May 2013, 08:24 PM   #54
skouliki's Avatar
I etched the dac board and the psu board . Assembly is almost complete but it was slow because im having some health issues lately. Cant say for sure but im probably gonna finish by the end of the week
Old 6th May 2013, 10:57 PM   #55
Hi Skouliki
Take care first, science can wait (;-)
Old 14th May 2013, 08:28 PM   #56
skouliki's Avatar
I run into a problem today. I soldered all regulators and went ahead with testing their voltages. The regs for positive supply all work ok, giving V+ 4.97-4.98V.
The regulator for the negative supply is measuring V+ 0.6v and gets very hot to touch. (By the way, the pictures i posted show the negative supply reg wired wrong)
I am using two seperate transformers to feed the regs with the ground pin of the negative supply reg as V-, and the Vout pin connected to ground plane.Am i overlooking something?
Edit: All regulators are positive
Old 15th May 2013, 06:35 AM   #57
marce is offline marce  United Kingdom
AD1865 schematic
I think you need a proper negative regulator.
Old 15th May 2013, 01:28 PM   #58
skouliki's Avatar
Tried two mic5207's and a 78l05. The same result, all get very hot and give 0.6v+ . Im going to buy a 79l05 tomorrow to give it a try hoping it works. Im still puzzled though why is this happening
Old 21st May 2013, 02:06 PM   #59
skouliki's Avatar
Using an 79l05 reg the dac works perfectly. Wired it today and sounds really good although using such a noisy reg for negative supply.Now i have to find a low noise negative reg with high-ish input voltage.I changed the layout of the board to reduce the number of slots in the ground plane. Picture quality is bad and the dac is a mess in its current form (long wires, uncut boards ,etc)
Old 21st May 2013, 03:06 PM   #60
Getting well Skouliki, great !
Question to the clocking and IV experts :
- If I was to connect 3 of these DACs to I2S out of Najda Digital XO, should I do something to synchronize properly the 3 DACs/avoid jitter (eg share the same clock ...)
- What is the best IV for these boards ? Zen/Cen/Sen ? (I have tube SRPP on my Raindrop board that work great, I could also duplicate them)
BR
Jean-Louis
AD1865 schematicHide this!Advertise here!
AD1865 vs AD1955 toufu Digital Line Level 50 15th April 2012 01:59 AM
Schematic for AD1865 ebay dac? mkanna Digital Line Level 1 13th May 2011 03:26 AM
AD1865-based dac schematic Sandor Digital Line Level 8 16th March 2010 07:01 PM
AD1865 w/ USB? dsavitsk Digital Source 6 28th February 2006 10:47 AM
AD1865 where? avian Digital Source 2 5th January 2004 07:17 AM
