AD1865 schematic - Page 5 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 10th April 2013, 01:12 PM   #41
marce is offline marce  United Kingdom
I presume the 24 pin device is the AD1865, if so you may want to check the Iout pins 4 and 21 they seem to be connected directly to GND, also the SJ pins.
The resistor and caps hanging off these lines also do not connect to anything apart from each other.
Is it based on the schematcis in post 4 or 5?
Old 10th April 2013, 09:59 PM   #42
skouliki's Avatar
Yes the big IC is AD1865. Im using the Iout schematic for both 24 bit and 24bit/192khz boards (24bit/192 khz is Vout on pavouks site).
I think i messed up the I/V resistor and cap connection, right? They should have a connection to ground
Old 10th April 2013, 11:52 PM   #43
skouliki's Avatar
the Iout pins are connected to ground Thanks marce for pointing this out
Old 11th April 2013, 07:02 AM   #44
Send a message via Yahoo to ThuyTN
How about a dual AD1865 with I2S input and I-out board?
Old 11th April 2013, 07:25 AM   #45
Glad to help, I spend all day looking at schematics, data sheets and PCB's, luckily the system I use the schematic and PCB parts are interlinked so I don't get these problems (Cadstar).
A good tip is to get some coloured highlighter pens and trace over the lines with yellow when manually transferring, green for the first check and red for the final check.
Old 11th April 2013, 09:07 AM   #46
O yes
Old 11th April 2013, 12:09 PM   #47
regal is offline regal  United States
Originally Posted by bambadoo View Post
O yes
Those extra 6 bits added with the logic chips proably aren't adding resolution, it was more of a marketing gimmick that one manufacturer came up with in the 90's, I would want dual mono with LSB adjust to get the most out of this chip.
Old 11th April 2013, 01:07 PM   #48
I've been dreaming about a dual AD1865 with I2S and balanced tube stage for a while but still nothing comes true. The only thing I came up with is this Matej's audio pages: Dual balanced NOS DAC AD1865 board but the author seemed to lost interest right after posting the layout... SPDIF is just the past to me right now.
Just a small board with headers for external modules (PSU, USB-I2S, IV) would be perfect. Heck, I will even offer free board as a gratitude for anyone comes up with this design.
Old 11th April 2013, 02:25 PM   #49
JLOP is offline JLOP  France
Skouliki
For guys not used to double faced board, could you post the meaning for red/Green square /round dots to make 100% sure ?
Tks
Jean-Louis
Old 11th April 2013, 09:07 PM   #50
skouliki's Avatar
Yellow traces are on the top side , green is the colour of ground plane(bottom side). After i correct the pcb i will send you the board files plus the toner transfer pdf's
AD1865 vs AD1955 toufu Digital Line Level 50 15th April 2012 02:59 AM
Schematic for AD1865 ebay dac? mkanna Digital Line Level 1 13th May 2011 04:26 AM
AD1865-based dac schematic Sandor Digital Line Level 8 16th March 2010 08:01 PM
AD1865 w/ USB? dsavitsk Digital Source 6 28th February 2006 11:47 AM
AD1865 where? avian Digital Source 2 5th January 2004 08:17 AM
Copyright 1999-2017 diyAudio
