not typical Audio DAC-IC's for Top Class Audio Applications - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 13th December 2012, 05:19 PM   #1
tiefbassuebertr's Avatar
Default not typical Audio DAC-IC's for Top Class Audio Applications
I have heard, any few manufacturers don't use the good known DAC IC types for their audio components like that one from regular audio brands (e. g. AKM, Burr Brown/TI, Analog Devices, ESStech (SABRE), Crystal/Cyrrus, Philips/NXP and Wolfson).
An example is this manufacturer:
http://www.audiomaat.nl/upload/docum...i%20critic.pdf
Maybe there are much more in the meantime.
Fast industrial devices seems to be much more suitable than the usual good known ones in order to obtain best possible sonic results.
Is this really true?
What types from which semiconductor brands are here of interest?
Thank you for advices.
Old 13th December 2012, 05:34 PM   #2
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
I'm very interested in exploring non-audio DAC chips for future designs. For example I have a few recovered AD768s and plan to obtain some of the newer comms DACs like AD9707.
DACs for comms applications have better characterization for audio in my estimation, not being solely rated by THD+N and SNR figures.
The heart ... first dictates the conclusion, then commands the head to provide the reasoning that will defend it. Anthony de Mello
Old 14th December 2012, 03:17 AM   #3
In what way? I just looked through the 768 and 9707 datasheets and they seem less informative than the typical audio DAC's datasheet. It's not, after all, AKM, Analog Devices, Burr Brown/TI, ESS, Cirrus/Crystal, NXP/Philips, or Wolfson's fault DIYers usually zero in on THD+N and DNR and ignore things like group delays or combined responses. Among the specs that do tend to show up in both types of datasheets SFDR does indicate contain some information THD+N doesn't, but the converse is also true. Similarly, A-weighted DNR doesn't say much about where a part's 1/f noise corner is but neither do noise densities at several MHz.
Old 14th December 2012, 04:08 AM   #4
abraxalito's Avatar
Glitch energy primarily as that's my primary hypothesis for what constitutes SQ in a multibit DAC. They show multitone performance, that's a much more music-like signal (crest factor) than a single tone. The variation of SFDR with frequency and with sample freq plots tell me quite a lot about the DAC's dynamic performance.
Old 14th December 2012, 05:10 AM   #5
Yeah, unfortunately I don't have a good enough oscilloscope to be able to make meaningful measurements of how much switching noise rides out of the outputs. But an output buffer with a couple passive RC stages between the DAC and the op amp pins should do a decent job on whatever escapes the DAC. Cirrus sets up their eval boards this way and it's always seemed kind of strange to me other manufacturers don't.
Old 14th December 2012, 05:12 AM   #6
abraxalito's Avatar
Yeah I originally thought an RC set above the audio band would lick it. But then I listened...
Old 14th December 2012, 10:02 AM   #7
here an old model without typical DAC-IC for audio:
Information wanted about Accuphase DP-70 DAC: 4 pices Intersil's 4-bit ICL 8019ACPD
http://www.analog.com/static/importe...als/MT-015.pdf
Old 15th December 2012, 08:07 PM   #8
Bernhard's Avatar
I have tested low level performance of DP70. Fail.
Old 15th December 2012, 09:02 PM   #9
Depends on what exactly one means by lick, I guess. A glitch is essentially an impulse and therefore is fairly flat in the frequency domain. As the the switching time for dynamic element matching has to be short compared to DAC's clock the impulse energy should have a bandwidth of tens to hundreds of MHz. RC filters cornered at ~50kHz reject the majority of this energy. So, if one's purpose in putting down a passive filter ahead of the output buffer's op amp is to prevent DAC switching transients from consuming the op amp's gain bandwidth product and slew rate, passive filtering does that well.
Such filtering is obviously not going to reject the in band portion of glitches. However, a corrolary of their broadband nature is THD, IMD, and DNR measurements all contain information about glitch energy. These are sometimes given in detail for an audio DAC's eval board, so one can have a pretty decent idea of in band behavior at sigma-delta part selection time. A more revealing test is DNR versus DC offset which, to my knowledge, is unfortunately published for only the ES9018 (slide 36) and WM8740 (figure 4---the "competitor's 117dB DAC" is likely the AD1853). DNR versus DC is primarily as a test for other issues but, to the extent glitch energy varies as function of output level, it captures that too (more here, though the talk starts rather slowly).
I'm curious as to what lead to the conclusion it's glitches you're hearing as opposed to other limitations of sigma delta DACs such non-peridodic steady state noise, nonlinear excess phase, or even just the impulse response of the antialiasing filter.
Old 16th December 2012, 03:23 AM   #10
abraxalito's Avatar
I think here we might be talking a bit at cross-purposes. I don't hear glitches on S-D - but then I gave up listening to S-D type DACs a couple of years ago. Glitch is one of the things that S-D is good at - but its soooo bad at other things that its just fallen by the wayside in my quest for the ultimate SQ.
So having come to the firm conclusion that multibit is the only way to get satisfying sound I've been working on reducing the glitches in that. You might find this thread I started in another place interesting - I'm working on a multibit DAC which will be public in both process and end result - Digital that sounds like analog. The no.1 aim is dynamics which I hear as the the main drawback of S-D DACs - although I have stopped listening to them, plenty of material I encounter has the characteristic sound as you'll note if you dig into the thread
LC networks in typical audio PSU applications random007 Power Supplies 33 22nd January 2011 03:03 PM
Top Flight DAC - very High End audio b_online Digital Source 78 1st July 2003 01:17 AM
Copyright 1999-2017 diyAudio
