diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Digital Line Level (http://www.diyaudio.com/forums/digital-line-level/)
-   -   HiFimeDIY 9023 + CS8416 COAX and OPTICAL input (http://www.diyaudio.com/forums/digital-line-level/224601-hifimediy-9023-cs8416-coax-optical-input.html)
azimut 29th November 2012 03:30 PM
Anybody tried it yet?
Hifimediy Sabre COAX/OPTICAL DAC. ES9023 + CS8416 115V
Is the trasformer a bit too close to the sabre?
Alphy 1st December 2012 05:06 PM
Any recommended box to install it in easily? Then I'll pull the trigger :-). Can't go wrong at this price.
northernsky 3rd January 2013 08:53 AM
Originally Posted by Alphy (http://www.diyaudio.com/forums/showthread.php?p=3265846#post3265846)
I made my ebay dac using Hammond chassis 1455 series and I liked it.
Northernsky
northernsky 10th February 2013 09:45 AM
Originally Posted by azimut (http://www.diyaudio.com/forums/digital-line-level/224601-hifimediy-9023-cs8416-coax-optical-input.html#post3262680)
Just now listening to music by this DAC with the chain:
macbook pro, M2tech hiface, dac, yarland m84 tube amp, fostex fe103 in BR box.
To me it is a clear step forward when compared with my 707 Superpro DAC and also to a PCM1798 ebay kit I also have.
More slam, and a bit of added detail.
northersky
northernsky 10th February 2013 09:31 PM
1 Attachment(s)
I have to bypass the S/PDIF RCA input because I want to put this dac in a chassis I already have, but I cannot recognize where is the input signal and the input ground on the pcb.
I attached a picture: I assume A is the ground and B is signal.
Am I right?
thank you for your help
northernsky
Copyright 1999-2017 diyAudio
