A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 22nd December 2013, 03:56 PM   #791
beardman is offline beardman  Denmark
Hi Bert
here are the link to the Shinko (they sound vey good)
Acoustic-Dimension, high-end audio and components for tube audio
oh sorry could not see the 5v powersupply on your picture--
for me the Doede dac is the best ever..have tried several other diy dac..
best Bjarne
Old 22nd December 2013, 04:14 PM   #792
watchtmouse is offline watchtmouse  Germany
watchtmouse's Avatar
Wow, thanks for the quick response, nice site.
Bert
Old 22nd December 2013, 05:10 PM   #793
Leeuwarden is offline Leeuwarden  Netherlands
Originally Posted by clivem View Post
If you want audiofool prose,
. Infer from that, whatever you like. Both are very high quality and you can build a superb DIY DAC using either.
Old 23rd December 2013, 03:46 AM   #794
Chanh is offline Chanh  Australia
Originally Posted by dddac View Post
These little boards are extremely convenient I must say
latest news, eight decks works perfectly. I am an happy man. next week we will do listening tests. will report back and start making things available....
for now merry
Welldone for 8-stacks! A happy man here also! I am now one step closer getting this 8-Stacks put together at not too distance future!
Please let us know how did you go with the listening tests? HoHoHo...!!!
Old 23rd December 2013, 01:12 PM   #795
KevinTams is offline KevinTams  United Kingdom
Just nailed my DDDAC together and tested on my bench supply. So far so good.
I've measured 2.2V output +ve to ground. 0.00V +ve to -ve outputs. It may be a daft question but why can't I use a single ended output on the +ve to -ve and forget the dc blocking caps?
Old 23rd December 2013, 01:17 PM   #796
WalterW is offline WalterW  Netherlands
Originally Posted by Glockenklang View Post
Walter, that's a very nice build .
Where did you get the enclosure?
Roel
Thanks! It's a Modushop Galaxy Magiorato GX388, the frontpanel is from Schaeffer AG.
They are now processing the same frontpanel with my customer provided 10 MM Alu front from Modushop.
So that will be even nicer, and necessary because when I was drilling and tapping a blind hole at the back to hold the LED-PCB, I almost drilled through ..... and now it shows a big bulge
Pass F5, F5Tv3, ACA, Aleph J, DDDAC1794, DCB1, BA3-preamp, VFET CSX1, Pass F6, Pass M2-HPA, VFET-X balanced, Pass J2
'If you see me talking to myself, don't worry. I'm getting expert advice'
Old 23rd December 2013, 02:47 PM   #797
Default Works
Deep breath and plug it in.
I forgot that the SBT needs the USB output to be enabled
Try again
This is just a lash up to test it. I'm powering it with a couple of cheap ebay sourced Chinese power supplies, a pair of caps from my parts box and mounted on a plank of wood. Hardly hifi is it. Yes it is.
I built this because I wanted to play hirez files and my Audio Synthesis Dax2 is 16/44.1 only. I've been listening to some serious kit from Linn, Naim and Audiolab and found nothing that made me want to part with the AS. Already this is easily the equal of the AS after 1hr of playing.
Now that I know it's OK I'll spend some time and effort to finish it to a standard it obviously deserves. Problem is that I'm listening instead of working
Next question is cinemags or Sowter, anyone heard both?
Doede you're the man.
Old 23rd December 2013, 03:58 PM   #798
dddac is offline dddac  Germany
DDDAC Audio
thanks for the flowers good to have some positive feedback! keeps me going
on the question, why not use just pos and neg terminal to avoid capacitors...
it might work, IF the amplifier which follows is isolated from ground. otherwise you will add the complete ground of your house to one of the outputs of the DAC. it might work fine indeed, but it might hum as hell.....
why not try it if you think the rest of the chain can float
www.dddac.com
Happy listening and building
Old 23rd December 2013, 07:35 PM   #799
I wired the dac using the balanced phases into my preamp with no cap. No hum, higher output and slightly better sounds. All good, no drawbacks as far as I can tell, but my system is dc blocked pre to power
Old 24th December 2013, 12:23 AM   #800
tuyen is offline tuyen  Australia
Send a message via MSN to tuyen
2w shinkoh tantalum resistors for IV + custom sowters from Doede (1:1 and 1:0.5 windings) = very nice!
The sowters have lowered the noise floor producing a blacker background. I can hear further into the music. Small naunces and delineation of notes/voice seem more fleshed out and essier to pick. The music seems to also have greater sense of purity and presence. Improvement in 3d soundstage clairty and resolution as well.
Coupling caps I have tried are wonder dynamicaps, jensen copper paper tube, ampohms, auricaps and duelund cast coppers. Duelunds being the most fluid, natural sounding while still having excellent resolution out of the various caps.
Sowters bring further improvement than the duelunds.
All IMO of course!
MERRY CHRISTMAS ALL and thank you again Doede! <3
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
