A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 19th December 2012, 03:28 PM   #71
clivem is offline clivem  United Kingdom
Originally Posted by BachAudioDK View Post
My comment on the 0.4% THD was more minded on, that this Chip (PCM1794) should be able to perform better even in NOS mode and with passive I/V.
Run it into a virtual ground and I'm sure it would be possible to get very near the datasheet spec.
Do you really need so high output of 1.2Vrms to drive your amp/speakers/headphones ?
(my guess is that during normal listning levels, your volume control is properly turned well below 12 O'Clock)
Hair trigger volume controls are one of my pet hates. My downstream gear is designed on the premise that sources put out 2V RMS and that I want 3/4 of the volume control to be useable. I don't doubt that what I had with the differential tube input stage and the 10R I/V resistors would give a better THD measurement. Didn't sound as good as the 133R passive I/V! (And to be honest, my initial expectations before I ever heard the DAC, just knowing the value of the default I/V resistor, was a slew limited, muddy, crappy sound. That it doesn't sound that way and I prefer it to an active stage that on paper should result in better performance, go figure......)
Old 19th December 2012, 11:31 PM   #72
pdb is offline pdb  Denmark
pdb's Avatar
Doede has added the DDDAC Power supply to his 1794 webshop - 5 and 12 volt / 1A in kits and assembled versions. Scroll down on this page
DDDAC 1794 NOS DAC - Non Oversampling DAC with PCM1794 - no digital filter - modular design DIY DAC for high resolution audio 192/24 192kHz 24bit
He has also updated the page about power supplies accordingly. Scroll down
Looks neat :-)
Per
Old 22nd December 2012, 09:01 PM   #73
tuyen is offline tuyen  Australia
Send a message via MSN to tuyen
Thanks for the heads up, Per.
Have been waiting for this!
Old 23rd December 2012, 10:05 AM   #74
northernsky is offline northernsky  Italy
thinking about getiing a kit, just a question.
I understood that no driver is required for Mac OSX 10.6 and later: am I right?
Thank you
northernsky
Old 23rd December 2012, 05:25 PM   #75
Lucien is the person to give you a definitive answer to that question. That's what it says on his website. Your question might be better asked in the WaveIO thread.
Old 23rd December 2012, 05:27 PM   #76
Is anyone (aside from Doede) running the WaveIO from a dedicated PS? I spent the day trying to hear any difference at all from it being powered from the USB bus or a dedicated power supply and I damned if I can hear any difference at all!
Old 23rd December 2012, 05:33 PM   #77
jeremysk is offline jeremysk
clivem: try hi-res flac.
Old 23rd December 2012, 05:52 PM   #78
Yes, I have been. When I first thought about it, higher sample rates, higher current draw, so any differences are likely to be more obvious at higher sample rates. I've listened to a bunch of native high-res material along with other stuff that I have software upsampled 44.1k -> 176.4k. Even had the DAC plugged into my headphone as well as speaker rig. Maybe what I used to consider to be golden ears have turned into cloth ears. LOL. I really can't hear any differences. Nothing subtle. Nothing at all.
I've also tried the laptop as well. So I've been listening bus powered driven from my Logitech Touch and bus powered from my old Samsung NC10 laptop running Linux.
Old 25th December 2012, 10:40 AM   #79
Panda2 is offline Panda2
Great project Doede!
I have a few Q...
Why 2 chips on 1 board? Is it dual mono?
How do you control volume?
Happy Holidays
Old 25th December 2012, 05:47 PM   #80
I'm not Doede, but I'll bite....
Yes, configured for dual mono, so one DAC chip for left channel, the other for right channel.
Either from the pre-amp that you plug the DAC into, or in software on the computer or whatever else you are using to feed it via USB.
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
