A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 3rd June 2018, 07:45 AM   #6611
NicB is offline NicB  Australia
Default PSU build issue?
Hi All,
I am having trouble with my 12 VDC power supply build - I am getting constant 17 VDC at the output and turning the trimmer resistor has no effect?
Does anyone have a schematic for this marked up with normal operating measurements? I have no idea how to calculate the expected value but I am capable of sticking the multimeter somewhere and comparing the number on the display to a known value :-)
Nic
Old 4th June 2018, 05:40 AM   #6612
dddac is offline dddac  Germany
DDDAC Audio
Originally Posted by NicB View Post
Hi All,
Nic
if turning the Trimmer has no effect it sounds like you flipped the small transistors position. meaning: switching the bc560 and bc550 or putting it 180 deg wrong
so two questions first.
1 does the LEDs light up normally
2. double check the transistors
www.dddac.com
Happy listening and building
Old 4th June 2018, 10:17 AM   #6613
szczemirek is offline szczemirek  United Kingdom
I want to say: Thank you very much Doede for your absolutely amazing support with my problem. All the best!
Old 4th June 2018, 03:42 PM   #6614
Bfpca is offline Bfpca  Canada
Originally Posted by Smartdriver View Post
Hi there Bfpca,
Thanks for the kudos.
The TVC's were bought at: Acoustic Dimension dot com, check "transformers" and scroll down to Silk Audio.
They run both, single ended or balanced.
I have one input, thats the one just above the umbellical cord from my external PSU
I have created multiple outputs:
Straight out DDdac balanced
Straight out DDdac single ended through Cinemags 15/15b
Output through TVC's
Balanced
Single ended (connected in the picture, play bi-amp)
Cheers, Paulus
Thank You Paulus for the information. You have lots of output options to explore with your DAC.
Happy Listening
Brian
Old 5th June 2018, 06:57 AM   #6615
DDDAC Audio
Thanks for the flowers I am happy I could help you and hope you will enjoy the DAC in its full functionality now !
www.dddac.com
Old 6th June 2018, 09:44 AM   #6616
Thanks Doede that fixed the problem!
I need some glasses.
Nic
Old 7th June 2018, 06:46 AM   #6617
DDDAC Audio
Nic
My pleasure and again happy I could help with remote diagnostics. I had this error already a few times with some DIY, hence the expected hit-rate was high
Next to my normal reading glasses with +2 (yes I NEED them as well)I have extra reading glasses in my hobby-lab with +3.5 . Only for soldering and PCB related work. For SMD work, I have the great nerdy looking head set with the 10x magnifying glasses flipped in front of my eyes
www.dddac.com
Old 14th June 2018, 10:41 AM   #6618
cHoc is offline cHoc  Netherlands
Send a message via MSN to cHoc
And so mine is done too. Well at least for the moment....
Yes, it is far from done.
The connections to the mainboard are not nicely done, i know.
The prints themselfs are nicely soldered.
I it this way as I will be changing it in the near future, with the berrystreamer, and the Cinemag transformers, so i thought, why bother...
At least it plays MUSIC!
It takes the digital input from a Meridian G98HD and output goes to a XTZ 100D3 with feed in Bi-amp (2x XTZ 100D3) a set of Xanadu HRS 20SE speakers.
First impressions: what a clean sound! As if i have been listening through sandpaper all this time....
Alive and kicking
Old 14th June 2018, 10:00 PM   #6619
hyped is offline hyped  Australia
Hi All,
Nic
Might be stupid question but are you getting any resistance change on the wiper of trimmer?
Old Yesterday, 07:49 PM   #6620
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Not much activity in this thread recently ;-)
I just finished another passive TVC that goes in between the DDDAC balanced output and the inputs of my tube amp and subwoofer amp. It's too good to be true... the TVC is a very good volume control with no signal loss! It uses the full balanced out from the DAC chips, and it helps avoiding ground loops.
I used the good old Sowter 9335 TVCs, this time with a Shallco 2x26 switch. Easy-peasy old style, no fancy microcontrollers and relays.
The TVC replaces a passive attenuator with fixed resistors. This was clearly not a good solution in my system. The impedance matching was not right, which resulted in poor sound quality depending on the volume setting.
No more resistive volume controls in my home
(except in the kitchen radio)
Good stuff!
[ audioroot.net | hifibau.ch ]
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
