A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old Yesterday, 04:37 AM   #6581
dddac is offline dddac  Germany
DDDAC Audio
Originally Posted by spacejay View Post
Hello all,
I have a problem with my DDDAC1794. Actually probably I don't but I thought I'd throw this open as someone here may know how it can be sorted .
Okay so I built the DAC a few years back and it has worked flawlessly ever since. I use it sporadically (I'm a vinyl sort of bloke) and keep it powered off. I have a comp running Windows 7 and have foobar.
This is how I remember the sequence of events. I wanted to use it yesterday but after powering it up I could get no lights to work. I fiddled about with it and re-installed the latest driver I had (V2.23.0) and the DAC came to life. To all intents and purposes it looked fine however there was no sound. I have checked W7 and it all looks fine, everything is 100% volume and nothing muted and the settings for foo match with those in the guide. The question is have I missed something obvious. Nothing had been changed since the last time I used it - the comp is a stand-alone music pc and as stated previously, rarely used. Any ideas to test if it is a software problem with the PC or if it the DAC itself?
did you try spdif? or do you have any means to check the I2S signals?
www.dddac.com
Happy listening and building
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
