A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 18th November 2017, 06:16 PM   #6401
LuisMCP is offline LuisMCP  Spain
LuisMCP's Avatar
Default Stopped Clock Operation with PCM1794
I'm wondering if it is possible to apply Stopped-Clock-Operation to PCM1794 in NOS mode.
Old 1st December 2017, 06:47 PM   #6402
cHoc is offline cHoc  Netherlands
Send a message via MSN to cHoc
Is this transformer also one that can be used as a substitute for the Cinemag or the Sowter?
And would it fare well against those?
AIT1 from Audience, the makers of the Auricaps.
http://audience-av.com/wp-content/up...16/09/AIT1.pdf
Alive and kicking
Old 1st December 2017, 06:57 PM   #6403
zigzagflux is offline zigzagflux  United States
zigzagflux's Avatar
Looks like a blatant copy of the Cinemag, datasheet and all.
Old 2nd December 2017, 10:41 AM   #6404
Bfpca is offline Bfpca  Canada
It is not a clone of the Cinemag 15k input transformer. Note that it is a 600:600 ohm isolation transformer. It looks like it may be manufactured by Cinemag but they state it uses special wire, so I would guess it’s a OEM adaptation of a Cinemag design, manufactured by Cinemag exclusively for Audience.
Not sure it would work well unless you had a lot of boards to drive it. The input impedance is specified at less than 600ohms which will require some current to drive if terminated properly with 600ohms on the secondary.
Also no voltage gain that you would get with the Sowther.
Old 4th December 2017, 05:12 PM   #6405
Originally Posted by Bfpca View Post
It is not a clone of the Cinemag 15k input transformer. Note that it is a 600:600 ohm isolation transformer. It looks like it may be manufactured by Cinemag but they state it uses special wire, so I would guess itís a OEM adaptation of a Cinemag design, manufactured by Cinemag exclusively for Audience.
Ok, not the ideal transformer, specially to start with....
Voltage gain was not an requirement for me, I was just looking if it would be a worthy transformer next to the other two in terms of (sound)quality.
I forgo on the inpedance difference between the two, I did not take that into account, thnx for pointing that out.
Alive and kicking
Old 3rd January 2018, 09:31 AM   #6406
dddac is offline dddac  Germany
DDDAC Audio
Wishing every one a great 2018. Hope we all find time for our hobby and having some creative ideas for the DIY :-)
www.dddac.com
Happy listening and building
Old 9th January 2018, 01:56 PM   #6407
stefan646 is offline stefan646
Happy new year !
I have a question regarding the signal input resistors (R1). There are there for line impedance matching? The Hermes - Cronus are having 33ohm resistors in the signals paths , so I am guessing it will be a good thing to change all the DAC boards R1 to 33ohm as well?
EDIT: with the Hermes Cronus connected directly to the DAC, without the main board
Old 9th January 2018, 05:20 PM   #6408
eduard is offline eduard  Netherlands
Send a message via Yahoo to eduard
Hello,
Happy new year to all dddac users who did share their precious information.
Next step will be to try berry streamer to compare it to the Aurender.
If playing files from a hardddisk in possible with the berry streamer.
Maybe open a new thread about it in a few weeks.
Greetings, Eduard
Old 9th January 2018, 05:21 PM   #6409
Hello,
Greetings, Eduard
Old 9th January 2018, 08:19 PM   #6410
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
I am running one of my DDDACs using the I2S output of an RPI+HifiBerry DAC+ Pro. The RPI runs Volumio. Playing from harddisk is no problem, and it also plays music via network (NAS / disk shares, AirPlay, etc.). Volumio also controls a stepped volume control (Allo Relay Attenuator). This whole setup works very well. Operation is super convenient and it sounds very, very good.
[ audioroot.net | hifibau.ch ]
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
