A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 17th June 2017, 04:32 PM   #6201
Studley is offline Studley  United Kingdom
Originally Posted by dddac View Post
actually my next thinking is to use one complete 8-stack for the LEFT channel and another for the Right channel. for true DIY easy to omplement of course as you lead the data Signal to the other side of the stack and the Audio current Output Need to be lead to one (half value) Rload.
Spdif Input and USB Input can be looped through. between Mainboards. and of course two poer supplies. than it become true double mono stereo
Did anyone ever try this? If so what was the impact on SQ?
Old 20th June 2017, 09:20 PM   #6202
Default DAC Boards
Shameless promotion but of potential interest to subscribers to this thread: I have some boards up for sale in Swap Meet.
Old 21st June 2017, 10:55 AM   #6203
chriss0212 is offline chriss0212  Germany
Default Max Input Voltage
Hi all
because i try to switch to akku- power i would like to know, what is the max. input voltage of the dddac?
thanks and greetings
christian
Old 21st June 2017, 03:08 PM   #6204
dddac is offline dddac  Germany
DDDAC Audio
Originally Posted by chriss0212 View Post
Hi all
christian
no problem up to 15 volt is ok. more important is de minimum voltage of 11.5 Volt
www.dddac.com
Happy listening and building
Old 21st June 2017, 04:43 PM   #6205
Dear Doede,
Thx for feedback
But 15 is maximum? Problem: with lipo this is a little bit on the edge in both directions
3 cells have nominal 11.1V but charging end Voltage is ~ 12.5V
4 cells have nominal 14.8 but I think they will have something between 16V and 17V at fully charged.
So... good question what to do
Greetings
Christian
Old 22nd June 2017, 01:08 PM   #6206
DDDAC Audio
Dear Doede,
Thx for feedback
Greetings
Christian
with 17 volts the 7810 on the DAC board will get a bit warmer, but it will still stay within limits
the 7810 will dissipate ~ 0,7 Watt at 17 volts
according to the datasheet the raise in temperature is 25 degrees per Watt, so it will be ok
www.dddac.com
Old 22nd June 2017, 05:24 PM   #6207
Dear Doede,
Thank you for the feedback
"Just in case" i put 2 diodes in series to the battery. This makes sure, that the Coltage will stay below 16v!
Works pretty good... and i don't hear any bad thing about it
Will try to play with some capacitors on the 12v input... will let you know the results
Greetings
Christian
Old 23rd June 2017, 05:54 AM   #6208
DDDAC Audio
Cool Good idea
Dear Doede,
"Just in case" i put 2 diodes in series to the battery. This makes sure, that the voltage will stay below 16v!
Greetings
Christian
Excellent Idea
www.dddac.com
Old 23rd June 2017, 04:17 PM   #6209
Originally Posted by mbrennwa View Post
If you can build a DDDAC, you can also build an "Aurender clone", but for a fraction of the price, and without software/vendor lock in. Just search diyAudio for Volumio and it's brothers and sisters.
I did try searching but came up with nothing. Can you point me to it?
Old 26th June 2017, 04:02 PM   #6210
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Volumio.org and a Raspberry Pi will get you very far. If you need top notch I2S output, add a reclocker such as the Kali.
Gesendet von meinem D5803 mit Tapatalk
[ audioroot.net | hifibau.ch ]
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
