A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
Old 27th May 2016, 06:49 AM   #5351
mbrennwa is offline mbrennwa  Switzerland
mbrennwa's Avatar
Originally Posted by eduard View Post
Hello,
I just dont know how to connect the secondairy site of the transformer because it has 3 wires and a cinch connector just have two places to solder something.
So where are the pink, orange and brown wire going.
Thanksalot, Eduard
Didn't you receive any documentation with your Sowters?
My Sowter seems to have different color code. Here's my secondary set up:
pink: signal
brown: GND
grey: not connected
Primary on my Sowters is red and white.
[ audioroot.net | hifibau.ch ]
"You have no clue of how an amplifier works." - AndrewT
Old 27th May 2016, 09:33 AM   #5352
dddac is offline dddac  Germany
DDDAC Audio
pink: signal
brown: GND
grey: not connected
Input is red and white do no use the grey
Output is pink brown. The orange is the center tap. You can use this for balanced loads or to reduce output voltage by half...
By the way, this information is all on my website in the technical document at the download section...
www.dddac.com
Happy listening and building
Old 27th May 2016, 12:57 PM   #5353
eduard is online now eduard  Netherlands
Send a message via Yahoo to eduard
Hello,
There is indeed some info on the website but only a xlr is pictured and i think most people ( like me) will use a cinch connector for output to the pre amp but now we know how to do it thanks!!!
Hoping to be able to play cd within a few days.
Then will focus on a power supply for the wave IO. I wanted to use a choke input but Doede told me to take that the voltage given to the board should be 5 volt +- 100mv so there should be some kind of regulation.
Doede is using an Aurender, thinking about getting one too later.
If i just need to get a power supply for the wave IO and buy the aurender it will be easier then adding a heap of circuits which sometimes still have issues.
What to use for ripping my cd collection when using the aurender? would i be sensaible to get a decent cd rom drive? just got a new one but it is far noisier than my old Philips who broke down after 8 years.
Greetings, Eduard
Old 27th May 2016, 10:05 PM   #5354
dwjames is offline dwjames  United Kingdom
dwjames's Avatar
The choke supply is great for the analog section of the dac, but the digital stuff has different requirements.
The analog section provides the voice for the dac to sing the music, so it benefits from a power supply which is very free and without restriction and which can react quickly to changing demands. The demands on this supply change depending on the music, so you want something dynamic here.
For the digital sections, they generally have quite fixed requirements and as long as they do not have their power drained or interfered by the analog requirement then are happy with a nice quiet regulated supply usually with quite a small current of a few hundred mA or so. Most regulators will not filter noise much above a few hundred kHz it seems, so for digital parts which run in the mhz and ghz then local capacitors are more important. High speed decoupling caps as close to the device as possible work nicely.
That's my take on it anyway. Hope that helps somehow.
James
Old 28th May 2016, 02:25 AM   #5355
Hello James,
Your words look very familar to me. Lol. It seemd like you did copy and post an old post of yourself.
Maybe this could be the reason that i wanna try a choke input in a differential mode with a 4000mH Lundahl. I could use this one if i decide to use a serie regulator. If i will use a shunt current drawn will be to high for this one so will have use a choke similar to the one i am using now 700mH 1A
I did read about the Belleson. They look promising but they are expensive but just need one.
Today i did finish the dddac output wiring. Tomorrow will buy some wood to replace the support of my present dac because the dddac has some extra height. Now weight without front plate is around 32 kilogrammes and it is on the some height as my head so i must take care choosing the parts surrounding the wave io but that will be just a samaller r core and two chokes and some aluminum to support these so probably will end up around 40 kilo.
Maybe i have to do a warming up before lifting it that high.
Greetings, Eduard
Old 28th May 2016, 06:54 AM   #5356
Extreme_Boky is offline Extreme_Boky  Australia
Analog supply in DDDAC design, does not really exist. The +12V supply is used to supply a digital I2S isolator located on XMOS board and the digital sections of DDAC decks. Hence, all supplies should adhere to fast digital decoupling principles... and avoid the darn chokes altogether.
The validity of this argument is further supported by fact that the latest shunt DDDAC decks already take a very good care of “analog” section of DDDAC decks through shunts implementation. Their very low output impedance will do wonders, especially in mixed signal design.
+5V supply has to be of very high quality, and it has to be able to provide very fast digital decoupling to XMOS board.
This was my theory from the early stages of experimenting with DDDAC. The more I thought about it, and the more I experimented with power supplies and chokes, the more it was obvious that chokes simply could not match a properly decupled voltage regulation, especially for XMOS board. This board draws very large amount of constant current, while at the same time, it has to be able to swing its I2S output at very fast rates.
Still, I am not saying that the sound of chokes (even if used in +5V XMOS supply) is bad, better, or worse compared to anything else. Whatever shakes your boat is fine by me.
I just mentioned what I found by a fair amount of measurements undertaken, and a lot of experimentation
Old 28th May 2016, 04:50 PM   #5357
Hello,
Today i wrote a message to Belleson to have some more information about the regulators that they have on offer to substitute the LF50 and the two LF33 on the mainboard.
AND of course the 5 volt 500mA ( maybe this one will be used to close to its limits?)or 2A for the wave IO supply.
I rememember reading some people did replace the 3 regulators on thje mainboard by Tent shunts if i am correct.
The Belleson are serie regulators so easier to install then the shunts. They have low voltage drop so probably just desolder the LF regulators and replace them with the Belleson which share the same pin out as the LF types.
Use google translate for the next link from Norway.
Of course it is about the dddac
DDDAC 1794 NOS DAC
I am sure that there is more info to be found if google translate will be able to translate it.
greetings, Eduard
Old 28th May 2016, 10:26 PM   #5358
carlsor is offline carlsor  United States
Default Belleson Vregs and Load Resistors
I use the 2amp Belleson 5V Vreg located right at the input terminal block of the WaveIO. See picture below. I made up a perfboard. I measured a load of about 450ma. I supply it with 7.5V from a 6.3VAC filament transformer with Schottky diodes and filter caps so the Belleson has to throw away 2.5 Volts of heat. A 12V supply would mean 9.5 volts of heat to dissipate which would require a HUGE heat sink. I thought I heard a SQ improvement from the Belleson here.
I also use Bellesons on my red main board and SPMs for the 3.3V digital sections of the DDDAC board which also sounded better to me. I asked Belleson if this Vreg required a minimum load to give the best regulation and they said YES - minimum of 10ma for the SPM. The PCM1794 uses much less than 10ma digital power so I added a 300ohm load resistor to increase the load which I thought also sounded a hair better. Maybe the standard LM33 Vreg would sound better if it had a 300 ohm load resistor.
I highly recommend Belleson for digital circuits.
Old 28th May 2016, 10:41 PM   #5359
Hello Carlsor,
I wanted to use the same idea for supplying the 5 volt to the wave IO. I think current drawn also depends on the sample rate so that is why i also wanna use the 2A model.
I think using long cables between the regulator and the circuit could harm the benefits of the regulator.
I did ask Belleson if a choke input power supply would be benificial for this 5 volt supply. On their website they write no preregulation is better but then a bigger cap could also be seen as some kind of regulation .
I will wait for their answer.
Of course the LF50 and LF 33 also have a LCLC supply at the input shared with the 12 volt needed to supply the 10 volt regulator which feeds the shunts.
Does the heatsink for the 5 volt has to be that big after all you are not waisting a lot of voltage across it?
Greetings, Eduard
Old 29th May 2016, 08:10 AM   #5360
Originally Posted by dddac View Post
yes, it is best if a signal is applied to the DAC. if nothing is connected the internal clock features of the dac can run hot as it sees nothing to correlate with.
of course you could switch on spdif, than there is always signal if for whatever reason you do not want to connect the WaveIO to the DAC
Hello,
Did use a switch to choose between spdif and wave io but did not connect the wave io board with the flat cable to the motherboard and with the other flatcable to the ledboard.
Did just mount the switch on the chassis. While moving the chassis around on my kitchen table i probably moved the switch over to the other side because when chjecking the input voltage to the mainboard it was 11,9 volt while so far it was always over 12,2 volts.
So moved the switch and it was the higher value again.
Did i do something wrong?
Will it be ok to just attach the wave io with the 2 flat cables.
The two '' switches '' on the wave io will be set as delivered one J12 ( for external 5 volt supply) the otther BRD ( for usb input)
Have no 5 volt supply to connect yet but will be safe to use it this way just in case i might flip the switch again?
Of course once it is in the rack the switch will be rock steady.
I was hoping to put in the rack but i guesss i will have to wait for an answer.
Greetings, Eduard
A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)Hide this!Advertise here!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 05:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 01:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 04:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
