A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input) - Page 53 - diyAudio
Go Back   Home > Forums > Source & Line > Digital Line Level
Old 16th August 2013, 03:19 PM   #521
Well,
I did order a pair of the Cinemag's. When the postman arrived it didn't take long before they were in my DAC. I still have the dac-solo (as Dick named it) so with one board. Today I went to a good friend and we just listened for a few hours. He has the four boards-DAC, with the Mundorf S/G/Oil.
Well my opinion, I think the Solo with Cinemags is better then the 4 boards without the transformers.
It makes the sound more round, fuller, a....very nice high also, more detail, richer and so on and on. For me, a very good upgrade! More power, but never sharper. Just try before you....
Setup at home:
Macbook Air, Amarra (and Audirvana Plus), DDDAC Solo with Cinemag, Triode Dicks Classic Three Preamp, Classic II 300B amp, and Klipsch La Scala's.
It makes Doede's DAC even more and more wonderful, what a good performance!!!! I was already Flabbergasted...but now I am even more :-)
Old 16th August 2013, 06:20 PM   #522
Undarra is offline Undarra  United Kingdom
I've just finished building my DDDAC and am running it with the SPDIF module, but have a small problem. When i first turn it on it doesn't lock to the incoming signal. If i remove the digital input and reconnect it it works fine and continues to do so. Has anyone else experienced this? and if so what could be the cause?
Many Thanks, Si
Old 16th August 2013, 07:57 PM   #523
IanS1 is offline IanS1  United Kingdom
Originally Posted by Jan Deckers View Post
Well,
Setup at home:
Thanks for your input Jan. I'm going to be ordering the Cinemags next week once I've returned from my late summer holiday.
I also have the 4 board DDDAC but have recently changed the capacitors from Mundorf SGO to Audyn Copper. I know it's considered best to completely remove the capacitors but the Audyn sound very good compared to the Mundorfs. The bass has much more weight and the mids/highs sound fuller too. I felt the Mundorfs were a little edgy at the top end and overall quite lean in comparison.
One thing is for sure, the Cinemags have really got some 'impressing' to do.
Old 16th August 2013, 08:04 PM   #524
Many Thanks, Si
Si, I'm using the SPDIF module and have had no issues with it at all.
How have you got the bridge connected for the clock speed? What about the other jumper for SYNC SPDIF or Re-Clock? I'm not sure if either of these can cause the issue you mentioned but worth checking perhaps.
Old 16th August 2013, 08:10 PM   #525
Originally Posted by Bas Horneman View Post
Perhaps try to set up a GB. We got them for a very decent price in 2005 with the DIYAUDIO GB.
Yeah, I bet they were a decent price back then. If anyone else is interested and wants to arrange a GB feel free to let me know.
Old 16th August 2013, 08:41 PM   #526
Hi Ian
Thanks for the feedback, I've fitted the links for re lock and 2MHz I think. Not sure if that is right. Do you know what you have yours set to? I won't be able to check mine till tomorrow.
Ps I may be interested in a group but of transformers depending on price
Cheers, si
Old 16th August 2013, 10:08 PM   #527
dddac is offline dddac  Germany
Hi Ian
Cheers, si
just post a Picture of the board so we can tell if it is ok...
www.dddac.com
Happy listening and building
Old 17th August 2013, 09:06 AM   #528
Hi doede
I haven't worked out how to post photos yet. I can see that I've linked where it says bridge B (for 2.8224 MHz click) and also Re-clocking. Is this correct? Also what are the benefits of re-clocking over sync mode? I think I've found the problem though, I noticed I hadn't connected the 75r resistor across the digital input phono connector.
I'll try to post pictures again later, and thanks for your help.
Cheers, Si
Old 17th August 2013, 10:12 AM   #529
Re-clocking uses the on-board clock and will restrict you to 16bit/44.1k, which is what I have done. I use a Sonos box as my streamer so limiting to 16/44.1 is not an issue for me.
'Sync mode' will allow up to 96k which is the limit of CS8414 SPDIF receiver chip.
Ah yes, the 75ohm resistor could be the issue.
Old 17th August 2013, 10:17 AM   #530
Thanks ian, that makes sense, I'm only using red book CD so I think I'll leave it as is for now. I'll fit the 75r resistor when I get home and hopefully that'll fix it. Need to decide whether to upgrade to four boards now!
FS: Audio Widget (modified) Async USB DAC 24/192 ESS 9023 headphone friendly ASIO KS 2A3SET Swap Meet 5 15th August 2012 04:52 AM
Show my PCM1794 DAC TSOLINK + COAX + USB input, Line and headphone AMP output AWaudio Vendor's Bazaar 3 2nd January 2012 12:44 PM
GodDAC - 192/24 USB DAC BizonGod Digital Source 36 30th June 2011 03:16 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
Copyright 1999-2017 diyAudio
